Oil pump gasket? #1510720
10/01/13 01:33 PM
10/01/13 01:33 PM
Badge Offline OP
Badge  Offline OP
I didn't get a oil pump gasket in the engine gasket kit. I ruined the existing gasket when I took the pump off. I am not having any luck finding one. This is the gasket that is between the pump and rear main. Do I need that gasket? Motor is a mid 80's 360.
Re: Oil pump gasket? [Re: Badge] #1510721
10/01/13 01:49 PM
10/01/13 01:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You don't really need the gasket, but if you can take a good look at the pump mounting surface to make sure it looks flat at least. Sometimes the cheapy remans are a little warped.
Re: Oil pump gasket? [Re: buildanother] #1510722
10/01/13 01:56 PM
10/01/13 01:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could make your own out of a thin piece of non-corragated cardboard.
Re: Oil pump gasket? [Re: Badge] #1510723
10/01/13 02:00 PM
10/01/13 02:00 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I'd just grab one at the parts store for a few dollars? Or if they don't have it ask for some gasket material and make your own with a rubber mallet.
Re: Oil pump gasket? [Re: Badge] #1510724
10/01/13 02:07 PM
10/01/13 02:07 PM
AndyF Offline
AndyF  Offline
Mancini Racing or Hughes Engines has those SB oil pump gaskets. They aren't usually stocked at most parts stores.
Re: Oil pump gasket? [Re: buildanother] #1510725
10/01/13 02:57 PM
10/01/13 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Lots of SB's had no gasket at all, any leakage there is all internal anyway.
Re: Oil pump gasket? [Re: John_Kunkel] #1510726
10/01/13 03:19 PM
10/01/13 03:19 PM
Badge Offline OP
Badge  Offline OP
I went ahead and made a gasket. Thanks for all the suggestions.
Re: Oil pump gasket? [Re: 80fbody] #1510727
10/02/13 09:45 AM
10/02/13 09:45 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
So you ask the knucklehead behind the counter for an oil pump gasket?
He'll bring you out an O-ring.
Guaranteed.
Re: Oil pump gasket? [Re: Commando1] #1510728
10/02/13 12:32 PM
10/02/13 12:32 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Commando1 - i didn't believe you so punched in the info online & s.o.b. it came back with the o-ring. LMAO.
Re: Oil pump gasket? [Re: 80fbody] #1510729
10/02/13 09:25 PM
10/02/13 09:25 PM
pennsylvania
poboyengineering Offline
pennsylvania
...he makes a mental note, thankful that the o-ring is available, as our hero has a good pump that needs only the o-ring.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
