Re: can't get the converter to line up
[Re: mopar_leaner]
#1510601
10/01/13 10:17 AM
10/01/13 10:17 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
somtimes you have to lift it up and down while you just barley turn it side to side.it helps ALOT if the trans is held vertical.is it in the vehicle?
[Re: mopar_leaner]
#1510602
10/01/13 10:19 AM
10/01/13 10:19 AM
RapidRobert
I get the grooves/notches to line up side to side or top to bottom just like you did then insert it with maybe a slight back & forth rotation so my alignment is dead on. I'd think spinning it would move the notches/grooves out of clocking alignment.
[Re: mopar_leaner]
#1510603
10/01/13 02:52 PM
10/01/13 02:52 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Slowly spinning the converter with a slight in/out motion has always worked best for me (it helps to hold your tongue just right) In worst case scenarios you can turn the trans up and rest it on the tailahaft and drop the converter in vertically using a couple of long bolts in two drive lugs. When correctly installed the drive lugs will be at least 1/2" in from the bellhousing face.
[Re: mopar_leaner]
#1510606
10/02/13 10:21 AM
10/02/13 10:21 AM
Posts: 1,317 Ohio
jlatessa
Ohio
If the previous owner took it apart like that, maybe he boogered up one or both of the splines enough so you are having problems. Not easy to get at the converter splines, but take a close look at the trans shaft with a magnifier and see if there is any distortion. Splines are necessarily a tight fit and any marring or burrs are going to be a problem. A mill file may correct it. Joe
[Re: mopar_leaner]
#1510610
10/03/13 12:05 PM
10/03/13 12:05 PM
RapidRobert
I bet the converter splines are fubared inside from what he did. You wouldn't happen to have another converter handy for a quick trial fit would you?
