Vacuum Advance Port
#1510197
09/30/13 08:34 PM
09/30/13 08:34 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Hey Guys
I just got my ThermoQuad back from Scott Smith at Harms Auto and I'm very pleased. However I'm trying to figure out the correct port to plug in to the carb from the vacuum advance. I've played around with mixed results, just thought I'd ask the experts around here for some advice.
Thanks, Darren
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
Re: Vacuum Advance Port
[Re: ChrgrCuda]
#1510198
09/30/13 09:06 PM
09/30/13 09:06 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The port that doesnt have vac at idle...
I am truckless..
[Re: 340SHORTY]
#1510199
09/30/13 09:17 PM
09/30/13 09:17 PM
ChrgrCuda
Texas, USA
That's what I have it hooked to. Looks like I'm in the right direction. Thanks!
[Re: ChrgrCuda]
#1510202
09/30/13 10:20 PM
09/30/13 10:20 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Some of them are. I think it requires a special tool? I personally have never messed with one.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1510203
09/30/13 11:30 PM
09/30/13 11:30 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The little screw in the vac pot adjusts WHEN the advance comes in,,, not the amount of advance. The advance is controled by the weights and the little springs...
I am truckless..
[Re: 340SHORTY]
#1510204
10/01/13 12:08 AM
10/01/13 12:08 AM
ChrgrCuda
Texas, USA
Got it, thanks Shorty. Which way controls how fat it comes in, clockwise or counter?
[Re: ChrgrCuda]
#1510205
10/01/13 11:48 AM
10/01/13 11:48 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Manifold vacuum is only out voted here on Moparts. It is not the incorrect port.
It has some advantages, just like ported.
This is one method to have big numbers at idle AND light throttle cruise, which equals better mileage. That's how many computerized cars run.
[Re: hp383]
#1510209
10/02/13 01:04 AM
10/02/13 01:04 AM
Magnum
um, what?
Whew... I thought maybe I was the only one lost on that.
A mild engine like to idle at more than 10 deg. 10 is the number most of us are stuck with due to starter kick back. Manifold vacuum advance is one way to achieve higher advance numbers during idle.
I hate to mention it here on "the old car forums" but idling at 10 degrees is not seen on fuel injected cars. Switching from ported to manifold vacuum advance is another way to achieve timing maps similar to todays cars.
Timing while cranking will be the same, total will be the same, partial throttle will be the same, just more timing during idle.
