Vacuum Advance Port #1510197
09/30/13 08:34 PM
09/30/13 08:34 PM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Hey Guys
I just got my ThermoQuad back from Scott Smith at Harms Auto and I'm very pleased. However I'm trying to figure out the correct port to plug in to the carb from the vacuum advance. I've played around with mixed results, just thought I'd ask the experts around here for some advice.
Thanks,
Darren
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Vacuum Advance Port [Re: ChrgrCuda] #1510198
09/30/13 09:06 PM
09/30/13 09:06 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The port that doesnt have vac at idle...
I am truckless..
Re: Vacuum Advance Port [Re: 340SHORTY] #1510199
09/30/13 09:17 PM
09/30/13 09:17 PM
Texas, USA
Texas, USA
That's what I have it hooked to. Looks like I'm in the right direction. Thanks!
Re: Vacuum Advance Port [Re: 340SHORTY] #1510200
09/30/13 09:56 PM
09/30/13 09:56 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
The port that doesn't have vac at idle...
You want no advance at idle, so the ported vacuum signal is the one your after.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Vacuum Advance Port [Re: hp383] #1510201
09/30/13 10:10 PM
09/30/13 10:10 PM
Texas, USA
Texas, USA
Yes sir, that's what I have it hooked to. Now about to try adjusting the vacuum advance. Is it adjustable and which way do I turn it for more advance?
Re: Vacuum Advance Port [Re: ChrgrCuda] #1510202
09/30/13 10:20 PM
09/30/13 10:20 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Some of them are. I think it requires a special tool? I personally have never messed with one.
Re: Vacuum Advance Port [Re: hp383] #1510203
09/30/13 11:30 PM
09/30/13 11:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The little screw in the vac pot adjusts WHEN the advance comes in,,, not the amount of advance. The advance is controled by the weights and the little springs...
I am truckless..
Re: Vacuum Advance Port [Re: 340SHORTY] #1510204
10/01/13 12:08 AM
10/01/13 12:08 AM
Texas, USA
Texas, USA
Got it, thanks Shorty. Which way controls how fat it comes in, clockwise or counter?
Re: Vacuum Advance Port [Re: ChrgrCuda] #1510205
10/01/13 11:48 AM
10/01/13 11:48 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Manifold vacuum is only out voted here on Moparts. It is not the incorrect port.
It has some advantages, just like ported.
This is one method to have big numbers at idle AND light throttle cruise, which equals better mileage. That's how many computerized cars run.
Re: Vacuum Advance Port [Re: Magnum] #1510206
10/01/13 04:21 PM
10/01/13 04:21 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
um, what?
Re: Vacuum Advance Port [Re: Golden-Arm] #1510207
10/01/13 06:31 PM
10/01/13 06:31 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
um, what?
Whew... I thought maybe I was the only one lost on that.
Re: Vacuum Advance Port [Re: ChrgrCuda] #1510208
10/01/13 06:44 PM
10/01/13 06:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC counter clockwise allows the advance to come in sooner, clockwise delays it..
I am truckless..
Re: Vacuum Advance Port [Re: hp383] #1510209
10/02/13 01:04 AM
10/02/13 01:04 AM
Magnum Offline
Magnum  Offline
um, what?
A mild engine like to idle at more than 10 deg. 10 is the number most of us are stuck with due to starter kick back. Manifold vacuum advance is one way to achieve higher advance numbers during idle.
I hate to mention it here on "the old car forums" but idling at 10 degrees is not seen on fuel injected cars. Switching from ported to manifold vacuum advance is another way to achieve timing maps similar to todays cars.
Timing while cranking will be the same, total will be the same, partial throttle will be the same, just more timing during idle.
Re: Vacuum Advance Port [Re: Magnum] #1510210
10/02/13 01:33 AM
10/02/13 01:33 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
UMMMMMMMM you better check out the timing specs on the TBI engines...
I am truckless..
