Re: Weight reduction effect on et
[Re: dillon383]
#1509818
09/30/13 06:49 AM
09/30/13 06:49 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
General rule of thumb is 1 tenth for every hundred pounds removed, so I would say about 5 hundredths.
Isn't there an ET where this changes? I had heard that this generalization was for 11.00 and slower.
[Re: moparguy7074]
#1509819
09/30/13 08:31 AM
09/30/13 08:31 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I've found it to be close, even in the low 10's Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1509820
09/30/13 08:53 AM
09/30/13 08:53 AM
Posts: 1,178 Indy
FlyFish
Indy
I found it depends on where the weight is. My car was a tenth quicker after removing my front bumper (33 lbs)...This weight is WAY up front, by removing it I got much better weight transfer, and better 60' times, which made for lower ET's.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1509821
09/30/13 09:20 AM
09/30/13 09:20 AM
Guitar Jones
Yes there is a point of diminishing returns, same goes for adding horsepower. 10 HP equals about a tenth, to a point. They are not linier.
[Re: jamesc]
#1509824
09/30/13 12:53 PM
09/30/13 12:53 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Years ago I had my 340 Dart at the track on Co-driver day which meant you could take a passenger if you had the seat belts and safety stuff. Well I had run 12.15 and then I put my 110 lb wife in the car and ran 12.16. Didn't make much difference which surprised me. Ron
[Re: 383man]
#1509825
09/30/13 03:04 PM
09/30/13 03:04 PM
KOS
I forgot i did the exact same thing took a 225lbs passager with me for a pass in my 9sec dart and never seen a tenth of diff.i also let someone who was 100lbs lighter than me drive my car(was a seasoned racer)hoping he would go quicker and actually went a couple hundreds slower than me.
