Weight reduction effect on et #1509814
09/29/13 11:59 PM
09/29/13 11:59 PM
Ohio, U.S.
73-Dart-sport Offline OP
Ohio, U.S.
I know their are some generalizations on this but can't find them in the archives. Approximately how much gain in et if you have a 50 lb. weight loss?
Re: Weight reduction effect on et [Re: 73-Dart-sport] #1509815
09/30/13 12:04 AM
09/30/13 12:04 AM
Galesburg IL.
dillon383 Offline
dillon383  Offline
Galesburg IL.
General rule of thumb is 1 tenth for every hundred pounds removed, so I would say about 5 hundredths.
Re: Weight reduction effect on et [Re: dillon383] #1509816
09/30/13 12:06 AM
09/30/13 12:06 AM
Ohio, U.S.
Ohio, U.S.
Thanks for the responses.
Re: Weight reduction effect on et [Re: dillon383] #1509817
09/30/13 01:01 AM
09/30/13 01:01 AM
On cars that weigh above 2800 lbs to start with
Re: Weight reduction effect on et [Re: dillon383] #1509818
09/30/13 06:49 AM
09/30/13 06:49 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Isn't there an ET where this changes? I had heard that this generalization was for 11.00 and slower.
Re: Weight reduction effect on et [Re: moparguy7074] #1509819
09/30/13 08:31 AM
09/30/13 08:31 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I've found it to be close, even in the low 10's
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Weight reduction effect on et [Re: deaks] #1509820
09/30/13 08:53 AM
09/30/13 08:53 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I found it depends on where the weight is. My car was a tenth quicker after removing my front bumper (33 lbs)...This weight is WAY up front, by removing it I got much better weight transfer, and better 60' times, which made for lower ET's.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Weight reduction effect on et [Re: FlyFish] #1509821
09/30/13 09:20 AM
09/30/13 09:20 AM
Guitar Jones Online laugh2
Yes there is a point of diminishing returns, same goes for adding horsepower. 10 HP equals about a tenth, to a point. They are not linier.
Re: Weight reduction effect on et [Re: Guitar Jones] #1509822
09/30/13 10:27 AM
09/30/13 10:27 AM
K
KOS Offline
KOS  Offline
K
i had a stock 5.0 mustang years ago that i got goin 13.0s....i wanted to get it in the 12s with the motor completely stock so i removed approx 300lbs off teh car and still couldnt get it in the 12s mind u different day different weather conditions that was the most extreme weight lost situation ive ever tried.ive taken 50/100/150lbs off of some mopars ive owned and same deal maybe a couple hundreds quicker.i believe if most the weight comes off teh nose of teh car that is where most the gains will be seen.
Re: Weight reduction effect on et [Re: KOS] #1509823
09/30/13 10:55 AM
09/30/13 10:55 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i can tell you this. we recently took 50# (about 20# in beadlocks) off a 2350# door car and saw no difference. i would NEVER have believed you could do that and see no difference
Re: Weight reduction effect on et [Re: jamesc] #1509824
09/30/13 12:53 PM
09/30/13 12:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Years ago I had my 340 Dart at the track on Co-driver day which meant you could take a passenger if you had the seat belts and safety stuff. Well I had run 12.15 and then I put my 110 lb wife in the car and ran 12.16. Didn't make much difference which surprised me. Ron
Re: Weight reduction effect on et [Re: 383man] #1509825
09/30/13 03:04 PM
09/30/13 03:04 PM
K
KOS Offline
KOS  Offline
K
I forgot i did the exact same thing took a 225lbs passager with me for a pass in my 9sec dart and never seen a tenth of diff.i also let someone who was 100lbs lighter than me drive my car(was a seasoned racer)hoping he would go quicker and actually went a couple hundreds slower than me.
