SHAKER TRIM RINGS #1509406
09/29/13 03:09 AM
09/29/13 03:09 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline OP
ek3  Offline OP
E
were all factory shaker trim rings made of steel ? meaning the part that is on top of the hood only that bolts on.
Re: SHAKER TRIM RINGS [Re: ek3] #1509407
09/29/13 03:31 AM
09/29/13 03:31 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
None of them were steel. They were zinc alloy die cast. BEA sells the absolute best reproduction there is, they even have the tiny Chrysler part# cast into the underside of them just like originals did.
Re: SHAKER TRIM RINGS [Re: ScottSmith_Harms] #1509408
09/29/13 03:50 AM
09/29/13 03:50 AM
E
ek3 Offline OP
ek3  Offline OP
E
thanks Scott. Mike @ BEA is # 1. I bought sig lamps from him. I am trying to determine if mine is factory or a good re-pop. been reading old posts but nothing to positively id it one way or the other. if it turns out to be a re-pop I will want the real deal. I need to know the details so I can buy the correct one . [have one local that is complete except its for a 4bbl]
Re: SHAKER TRIM RINGS [Re: ek3] #1509409
09/29/13 08:48 AM
09/29/13 08:48 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Just bear in mind that the trim ring that bolts to the hood is different between Challenger and 'Cuda.
For 'Cuda, there are a few choices, and BEA is hands-down the best.
For Challenger, it's either find an original or be prepared to work with some of the repros. That said, the ones from Harms/RestoRick (if they're still available) are probably your best bet.
Re: SHAKER TRIM RINGS [Re: YYZ] #1509410
09/29/13 11:01 AM
09/29/13 11:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
IIRC - if it's Challenger and has a part number it's original. Got pics?
Re: SHAKER TRIM RINGS [Re: 6bblgt] #1509411
09/30/13 12:35 AM
09/30/13 12:35 AM
E
ek3 Offline OP
ek3  Offline OP
E
Pictures.. best I can get for now . hard time getting them sized for the website.
Re: SHAKER TRIM RINGS [Re: 6bblgt] #1509412
09/30/13 12:40 AM
09/30/13 12:40 AM
E
ek3 Offline OP
ek3  Offline OP
E
any part # for the hood or just the rings?
Re: SHAKER TRIM RINGS [Re: YYZ] #1509413
09/30/13 12:45 AM
09/30/13 12:45 AM
E
ek3 Offline OP
ek3  Offline OP
E
This is a Challenger 1971 nov-dec 70 built date. that's what I want to do. if the one I have is not factory [and I think its not]I know where the whole set up is . I just don't know how to tell if it's factory correct for either one ...
Re: SHAKER TRIM RINGS [Re: ek3] #1509414
09/30/13 01:40 AM
09/30/13 01:40 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The under hood brace looks like a reproduction, Cuda style.
Re: SHAKER TRIM RINGS [Re: ScottSmith_Harms] #1509415
09/30/13 01:59 AM
09/30/13 01:59 AM
E
ek3 Offline OP
ek3  Offline OP
E
? tac welds , spot welds, crimp spots ? is there a dead give away on this hood?
Re: SHAKER TRIM RINGS [Re: ek3] #1509416
09/30/13 02:05 AM
09/30/13 02:05 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
All of the above as well as the overall shape of the stamping
Re: SHAKER TRIM RINGS [Re: ScottSmith_Harms] #1509417
09/30/13 02:10 AM
09/30/13 02:10 AM
E
ek3 Offline OP
ek3  Offline OP
E
I will get some good photos of the one I can buy and post them here and see if that one looks right! Thanks, very much for looking at this.
Re: SHAKER TRIM RINGS [Re: ek3] #1509418
09/30/13 11:22 AM
09/30/13 11:22 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That is almost certainly a Gene Gregory hood, more than the original number of spotwelds, plus he tack welded in places where the underbrace would not stay and used smaller sotwelder tips.
The longer than original studs on the trim rings are also a giveaway of his rings.
Here are a few photos of my original Challenger hood.
Notice length of the trim ring stud and size of spotwelds..
Re: SHAKER TRIM RINGS [Re: mccannix] #1509419
09/30/13 11:26 AM
09/30/13 11:26 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
more showing the spotwelds and not all on the very edge like his..
Re: SHAKER TRIM RINGS [Re: mccannix] #1509420
09/30/13 11:28 AM
09/30/13 11:28 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
original seam sealer.. the above are only some of the things to look for when examining the hood you are going to look at..
Re: SHAKER TRIM RINGS [Re: mccannix] #1509421
09/30/13 12:42 PM
09/30/13 12:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Challenger under braces were unique from Cuda. The ONLY correct ones were originals or the Harms reproduction (now sold by www.restorick.com)
Re: SHAKER TRIM RINGS [Re: ScottSmith_Harms] #1509422
09/30/13 02:07 PM
09/30/13 02:07 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
also if examining what you think appears to be an original hood, always look close at the front at the top of the underbrace where you will see this very prominent wrinkling in the sheetmetal, easily distinguishable from an AMD, Goodmark or anyones reproduction underhood brace that I have ever seen.
Re: SHAKER TRIM RINGS [Re: mccannix] #1509423
09/30/13 02:11 PM
09/30/13 02:11 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
another shot...
Re: SHAKER TRIM RINGS [Re: mccannix] #1509424
10/01/13 01:03 AM
10/01/13 01:03 AM
E
ek3 Offline OP
ek3  Offline OP
E
THANK YOU ! everyone...... scott, dan, YYZ, and mccannix, the photos will really help with future id on factory hoods.[phone call] to mike over @ BEA big time plus for the info about -NOT-breaking the trim ring bolts when restoring the hood ++++! this is what " makes " moparts in my op. Knowlage backed up with the facts.
Re: SHAKER TRIM RINGS [Re: ek3] #1509425
10/03/13 11:30 PM
10/03/13 11:30 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
OEM
