Re: SHAKER TRIM RINGS
[Re: ek3]
#1509407
09/29/13 03:31 AM
09/29/13 03:31 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
were all factory shaker trim rings made of steel ? meaning the part that is on top of the hood only that bolts on.
None of them were steel. They were zinc alloy die cast. BEA sells the absolute best reproduction there is, they even have the tiny Chrysler part# cast into the underside of them just like originals did.
[Re: ScottSmith_Harms]
#1509408
09/29/13 03:50 AM
09/29/13 03:50 AM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
thanks Scott. Mike @ BEA is # 1. I bought sig lamps from him. I am trying to determine if mine is factory or a good re-pop. been reading old posts but nothing to positively id it one way or the other. if it turns out to be a re-pop I will want the real deal. I need to know the details so I can buy the correct one . [have one local that is complete except its for a 4bbl]
[Re: YYZ]
#1509413
09/30/13 12:45 AM
09/30/13 12:45 AM
ek3
Just bear in mind that the trim ring that bolts to the hood is different between Challenger and 'Cuda.
For 'Cuda, there are a few choices, and BEA is hands-down the best.
For Challenger, it's either find an original or be prepared to work with some of the repros. That said, the ones from Harms/RestoRick (if they're still available) are probably your best bet.
This is a Challenger 1971 nov-dec 70 built date. that's what I want to do. if the one I have is not factory [and I think its not]I know where the whole set up is . I just don't know how to tell if it's factory correct for either one ...
[Re: ek3]
#1509416
09/30/13 02:05 AM
09/30/13 02:05 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
? tac welds , spot welds, crimp spots ? is there a dead give away on this hood?
All of the above as well as the overall shape of the stamping
