How to locate a 4 speed hump in an A-body??? #150911
11/14/08 04:04 PM
11/14/08 04:04 PM
So Cal
GoManGo70Bee Offline OP
super street
super street
So Cal
I am installing a 4 speed setup in my 67 Dart sedan. It is stripped right now getting ready for paint and I would like to install the 4 speed hump. How do I locate it so it is in the exact right place?
70 Superbee 383 4 speed 70 Hurst 300 67 Dart sedan 74 Ramcharger 03 Hemi Ram 1500 4X4
Re: How to locate a 4 speed hump in an A-body??? [Re: GoManGo70Bee] #150912
11/14/08 04:08 PM
11/14/08 04:08 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I will be doing the same thing on my 69 Dart and would like to know the answer to this question as well.
Re: How to locate a 4 speed hump in an A-body??? [Re: GoManGo70Bee] #150913
11/14/08 04:12 PM
11/14/08 04:12 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
The way I'm going to do it on my '73 Dart Sport is to first get the transmission bolted up and, from under the car, push the shifter up against the floor and mark the center of where the shifter hits the floor.
I'll locate the hump based on that.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: How to locate a 4 speed hump in an A-body??? [Re: 340727dart] #150914
11/14/08 04:18 PM
11/14/08 04:18 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
The shifter does not come through the hole exactly centered either.... He is a pick of my 1969 Original 4-speed car.
Re: How to locate a 4 speed hump in an A-body??? [Re: Cuda340] #150915
11/14/08 04:19 PM
11/14/08 04:19 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
2
Re: How to locate a 4 speed hump in an A-body??? [Re: 340727dart] #150916
11/14/08 05:14 PM
11/14/08 05:14 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
That's how I did it on my '77 Aspen using a '73 A-body hump. I have some pics and a brief write-up on the process HERE , which will be very similar for an A-body.
I wouldn't be overly concerned about getting the hump perfectly postioned, as there was surely some variety from the factory from car to car. Once you set the hump in place and start opening up the hole, it will darn near locate itself.
Remember, you can always cut the opening larger...
Re: How to locate a 4 speed hump in an A-body??? [Re: Cuda340] #150917
11/14/08 05:17 PM
11/14/08 05:17 PM
With the trans in place, mark the floorboard and cut it just large enough so there is room to bolt the shifter and linkage to the trans. Once they are bolted in, you can set the hump loosely in position and figure out where it needs to be so that the hump fits the floor and the shifter can go into all gears w/o hitting the opening in the hump. Don't think you'll have a lot of leeway as to where to put it so the shifter actually works, but it won't hurt to make sure the hump clears the seat, too.
Re: How to locate a 4 speed hump in an A-body??? #150918
11/14/08 05:28 PM
11/14/08 05:28 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
The hump pretty much centers itself on the tunnel. Lay it in place and trace the outline w/a magic marker. Trace another line approx. 1.5" inward from the original outline and cut away. Do not cut thru the structural support. It's a big hole but you need clearance for the 1-2, 3-4 shift rods as they are above the structural support and skewed towards the left. The rev. rod goes underneath the support. Mount the b/h, trans, shifter w/handle and lay the boot over the handle then on the hump. Mark your final location. The left rear of the hump DOES NOT seal properly to the floor as you can see in the pic so you need to patch it. I installed a repop'd hump. Weld every 2-3" in place and apply seam sealer on the top and bottom.
Re: How to locate a 4 speed hump in an A-body??? [Re: Pntastar69] #150919
11/14/08 05:35 PM
11/14/08 05:35 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Holey Moley!!!
Re: How to locate a 4 speed hump in an A-body??? [Re: Pntastar69] #150920
11/14/08 09:20 PM
11/14/08 09:20 PM
So Cal
super street
super street
So Cal
Looks great!!! You are right, as far as left and right, it centers itself. Its the front to rear im worried about. I would love to have the trans in it so I can use that but my car is stripped right now. Anybody have any measurements?
Re: How to locate a 4 speed hump in an A-body??? [Re: GoManGo70Bee] #150921
11/14/08 10:07 PM
11/14/08 10:07 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You could temporarily put the cross member in then bolt the trans to it to make sure its in the right place. Not as good as having the whole engine/trans in but I bet it would get it close enough.
Re: How to locate a 4 speed hump in an A-body??? [Re: 69Cuda340S] #150922
11/14/08 11:27 PM
11/14/08 11:27 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Does anybody know the reason for the small bracket on the back top corner of the hump? I never did get a definite answer? Mine is a non-console car and it seems like the bracket will keep the carpet from sitting flat? I'm just wondering what's the purpose of it?
Re: How to locate a 4 speed hump in an A-body??? [Re: RoadRunnerJD] #150923
11/15/08 12:57 AM
11/15/08 12:57 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
When I asked a few months ago I was told it was a forward limiting strap for bench seat cars.
Re: How to locate a 4 speed hump in an A-body??? [Re: In_The_Pink] #150924
11/15/08 01:08 AM
11/15/08 01:08 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
As stated the hump really only fits in the correct place. I laid the hump in and sprayed black pain all around it and cut about 1/2" inside the line of paint.
Re: How to locate a 4 speed hump in an A-body??? [Re: Jim_Lusk] #150925
11/15/08 01:18 AM
11/15/08 01:18 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Where was this thread when I atarted on mine???
I did the marker etc. I also have a 74 hump car in the drive way to peek at. They should tell you the repop hump is for the 75-76 cars.
Got mine from Dante's it fits good.
Only one MFR?
I have mine drilled to attach with caulking tube sized RTV and stainless screws. I painted the top satin black the bottom is bright white so it will reflect light for working under the car.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: How to locate a 4 speed hump in an A-body??? [Re: Rug_Trucker] #150926
11/15/08 01:20 AM
11/15/08 01:20 AM
Rug_Trucker Offline
Rug_Trucker  Offline
Re: How to locate a 4 speed hump in an A-body??? [Re: In_The_Pink] #150927
11/15/08 11:53 AM
11/15/08 11:53 AM
the house on the left.
cogen80 Offline
cogen80  Offline
that makes sence
