Re: Over Drive Trans in a Big Block Mopar options? [Re: CKessel] #1508831
10/09/13 11:13 PM
10/09/13 11:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
wilcap adapters www.wilcap.com sells adapters to put a GM trans behind a BB mopar. You can use this to put a GM 700r4 or a 200-4r behind a BB mopar. The GM transmissions are pretty wimpy in stock form but they can be built, and they are small enough to not make you do torsion bar mods.
I'm putting a t56 6-speed in mine. Quicktime makes a bellhousing for around 600 bucks. The swap will require floor pan and crossmember mods and not be easy on the wallet either.
Re: Over Drive Trans in a Big Block Mopar options? [Re: DaytonaTurbo] #1508832
10/10/13 02:22 AM
10/10/13 02:22 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Over $3grand for them to do a swap you can do with the Ultra bell for less than a grand. That's bell a good used trans and drive shaft shortening. Id rather save money. Im planning an ultra bell/518 swap in the future bit That's when money allows. Im helping hp383 with a swap. Its been slow as he live over 90miles from me and I now have a 4month old little girl but hope to have it pretty well close to done given no issues or Racoons arise again next weekend. 93 Ramcharger with a 440/518 and 3/4ton axles
Re: Over Drive Trans in a Big Block Mopar options? [Re: 76dodgeboy] #1508833
10/10/13 02:47 AM
10/10/13 02:47 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Best way I have seen.PATC. You do have to cut part of the block off and use their adapter but this conversion looks to be more reasonably priced.Usual driveshaft and rear mount mods.
http://www.transmissioncenter.net/SwapInformation.htm
Leave the gun.......take the Cannoli's....Mike
Re: Over Drive Trans in a Big Block Mopar options? [Re: CKessel] #1508834
10/10/13 07:04 AM
10/10/13 07:04 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The easiest and possibly least costly/hassle is 727 with Gear vendors.
From a $$$ standpoint this is not true, I know I just did it on my Duster 2 years ago. Even if I were utilizing it on a big block with an ultrabell it still would be cheaper than a gear vendors unit.
Purchased a core trans from salvage yard, rebuilt it, shift kit, larger front drum and aluminum servo piston from ebay, convertor from Hughes and had the driveshaft shortened = still cheaper than GV.
Better OD ratio with lockup to boot, works great. GV will be less work since you just have to replace the tailshaft on the 727, some wiring and get the driveshaft shortened.
"I think its got a hemi"
Re: Over Drive Trans in a Big Block Mopar options? [Re: gdonovan] #1508835
10/10/13 04:59 PM
10/10/13 04:59 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I don't think I will attempt welding a new bell housing on..... Looking at the JVX adapter now......... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Over Drive Trans in a Big Block Mopar options? [Re: tpabayflyer] #1508836
10/11/13 12:14 AM
10/11/13 12:14 AM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I've read that it is not real difficult to make an adapter plate for a transmission swap. If a person can find a machine shop with reasonable rates, they may be able to make one for a reasonable price. I've never looked into this personally, but I know a man had a local shop make an adapter plate for him. I have NO idea on how much it cost.
A second idea that may work for a cruiser type of car is to use the 833OD transmission. These transmissions aren't real strong, but they are fairly easy to adapt. (No modifications to the car are needed if the car is already set up for a manual transmission)
