Over Drive Trans in a Big Block Mopar options? #1508811
09/28/13 03:19 AM
09/28/13 03:19 AM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
Is it just the costly gear vender's unit added to. The old 727
OR Cut the 727 add a special hub-bell and converter on your old trans? That is after you cut the original hub/bell off you old trans right?
Any other options that are easy and less $$?
If not I know why guys git 360 and stick a 518 in
Anyone?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Over Drive Trans in a Big Block Mopar options? [Re: 340SIX] #1508812
09/28/13 05:18 AM
09/28/13 05:18 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
If I wanted a 518 behind a bigblock I would do the bell-cutoff thing and have the old 727 bellhousing rewelded to the 518-housing.
The aftermarket JW bellhousing which simply bolts to the original pumpbolts doesn't seem 'right' to me, although it's probably a non-issue since I've never read about any issues with that.
Re: Over Drive Trans in a Big Block Mopar options? [Re: BigBlockMopar] #1508813
09/28/13 06:52 AM
09/28/13 06:52 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I imagine getting that done and properly lined up would cost as much as a JW Ultrabell.
Don't be the exception.
Re: Over Drive Trans in a Big Block Mopar options? [Re: 340SIX] #1508814
09/28/13 10:13 AM
09/28/13 10:13 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have a 518 here waiting for its call to service. But, according to another post here, the conversion bell housings are back ordered big time.
Master, again and still
Re: Over Drive Trans in a Big Block Mopar options? [Re: Supercuda] #1508815
09/28/13 12:26 PM
09/28/13 12:26 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
These guys have been doing them for years:
http://dbqtranztk.com/
Give Tim a call and he will set you straight!
JB Rhinehart, Realist
A-Body's RULE!
Re: Over Drive Trans in a Big Block Mopar options? [Re: Rhinodart] #1508816
10/01/13 08:55 AM
10/01/13 08:55 AM
NC
HMcCandless_Jr Offline
NC
My dad has done 2 of them one with the JW Ultrabell and one where they cut the case off and welded a big block case to the 518 back, its a great way to go as you can run the overdrive and get the motor down to 1500 rpm at 60mph with a 355. Message me if you have any questions.
Re: Over Drive Trans in a Big Block Mopar options? [Re: Rhinodart] #1508817
10/01/13 11:11 AM
10/01/13 11:11 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Great guy to talk to. Lots of information about Mopar transmissions.
you supply a empty 727 case(only needs the bellhousing), a core A500 42RH transmission, your car to install it in and roughly $3600. +/- and You drive it home! Overdrive and Lockup.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Over Drive Trans in a Big Block Mopar options? [Re: Copper Dart] #1508818
10/01/13 11:18 AM
10/01/13 11:18 AM
Copper Dart Offline
Copper Dart  Offline
What about the JVXRACING.COM Adapter plate.
If I read correctly, they make a thin adapter plate to bolt a A518 directly to a Big Block with the required spacers to keep the Starter, Converter and Ring Gear all in the correct location?
P.S. John Vinson will answer any questions you have.
His adapter sells for $675. His Heavy Duty In-house Built Transmission for $2200. and the Base lock-up converters (aprox 2800rpm stall) start at $450. +
Quite a bit of mods required to the trans cross member area and of-course shorten the drive shaft.
Re: Over Drive Trans in a Big Block Mopar options? [Re: Rhinodart] #1508819
10/03/13 01:15 PM
10/03/13 01:15 PM
IL
furious70 Offline
furious70  Offline
IL
I also have one of Tim's a500's behind my turbo 383.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Over Drive Trans in a Big Block Mopar options? [Re: furious70] #1508820
10/03/13 05:24 PM
10/03/13 05:24 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have one buddy that did an adapter plate(unsure of source) that put a 518 behind his 440 6 pack...works awesome!! I have another buddy that runs an Ultrabell in a low 8 sec. nitrous door car without issue. Either should work just fine!!
Re: Over Drive Trans in a Big Block Mopar options? [Re: BigBlockMopar] #1508821
10/03/13 05:49 PM
10/03/13 05:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The UltraBell has an SFI rating. That means it's been tested and passed.
- Stu Harmon
Re: Over Drive Trans in a Big Block Mopar options? [Re: feets] #1508822
10/03/13 09:00 PM
10/03/13 09:00 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Ultrabell bellhousings for BB mopar will not be available until next hear at the earliest....
They are changing foundries and the change will take time so they say.... I hope they are not coming over on a slow boat from china?? Soooooo... I guess I have to chomp up my spare 727 for the bellhoising to install on my A-518....... Anybody have any pointers on how to do this reasonably accurately??
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Over Drive Trans in a Big Block Mopar options? [Re: tpabayflyer] #1508823
10/03/13 10:13 PM
10/03/13 10:13 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Hoping for a good answer here.
Re: Over Drive Trans in a Big Block Mopar options? [Re: drew72] #1508824
10/04/13 01:19 AM
10/04/13 01:19 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
There is this one. I think they were the first.
http://www.jvxracing.com/Adapters.htm
edit Oops beat to the draw.
Kevin
Re: Over Drive Trans in a Big Block Mopar options? [Re: tpabayflyer] #1508825
10/08/13 11:33 PM
10/08/13 11:33 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Here is a link on welding the bellhousing from a 727 to an A518, the guys name is GregCon he apparently built a jig to do this accurately.
https://board.moparts.org/ubbthreads/showflat.php?Number=6077119&page=0
Re: Over Drive Trans in a Big Block Mopar options? [Re: chargerbr549] #1508826
10/09/13 05:38 PM
10/09/13 05:38 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
can you put the 518 guts and tailshaft on a 727 case??
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Over Drive Trans in a Big Block Mopar options? [Re: 440lebaron] #1508827
10/09/13 07:07 PM
10/09/13 07:07 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The OD tailshaft will not bolt to the 3 speed case.
Re: Over Drive Trans in a Big Block Mopar options? [Re: 135sohc] #1508828
10/09/13 07:18 PM
10/09/13 07:18 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
given the desire for something like this, it's amazing there aren't more favorable options by now.
Or maybe there isn't that much demand after all? It does require cash and floor modification.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Over Drive Trans in a Big Block Mopar options? [Re: VincentVega] #1508829
10/09/13 07:26 PM
10/09/13 07:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
There are several options but none of them are easy on the wallet.
- Stu Harmon
Re: Over Drive Trans in a Big Block Mopar options? [Re: 340SIX] #1508830
10/09/13 09:49 PM
10/09/13 09:49 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
The easiest and possibly least costly/hassle is 727 with Gear vendors. From there you have the 518 unit which was behind the a-motors, diesels and v10. Next would be the Kiesler gm based unit or the gm based unit from TCI. Big bucks on those two. On the 518, depending on what year you use and preferably 95 and older, you have lock up converters or non lock up. The non lock up was used on the v8's I believe till 90 or 91 and on the diesel till 93. Past 94 they are all lockup. A custom lockup converter will be more dough than non of course. You don't want to use a reman stocker. Hand grenade in waiting. If you find a diesel or v10 unit, thay have heavier duty internals on the planetaries, drums, more clutches[ like a hemi] on all packs. You can update the v8 trans with these parts but its an added expense. Lock up trans will require two switches to operate the lock up and od, non lockup just need one for lock up. 96 on trans is full electronic and expensive to retrofit because it need a stand alone trans controller. Pick your poison. I went 727 w/gv.
Carl Kessel
