Re: Over Drive Trans in a Big Block Mopar options?
[Re: CKessel]
#1508831
10/09/13 11:13 PM
10/09/13 11:13 PM
DaytonaTurbo
Manitoba, Canada
wilcap adapters www.wilcap.com sells adapters to put a GM trans behind a BB mopar. You can use this to put a GM 700r4 or a 200-4r behind a BB mopar. The GM transmissions are pretty wimpy in stock form but they can be built, and they are small enough to not make you do torsion bar mods. I'm putting a t56 6-speed in mine. Quicktime makes a bellhousing for around 600 bucks. The swap will require floor pan and crossmember mods and not be easy on the wallet either.
[Re: 76dodgeboy]
#1508833
10/10/13 02:47 AM
10/10/13 02:47 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Best way I have seen.PATC. You do have to cut part of the block off and use their adapter but this conversion looks to be more reasonably priced.Usual driveshaft and rear mount mods. http://www.transmissioncenter.net/SwapInformation.htm
Leave the gun.......take the Cannoli's....Mike
[Re: gdonovan]
#1508835
10/10/13 04:59 PM
10/10/13 04:59 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I don't think I will attempt welding a new bell housing on..... Looking at the JVX adapter now......... TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
