School me - BB vs SB in an A body
#1508497
09/27/13 05:19 PM
09/27/13 05:19 PM
Posts: 1,185 Nanaimo, BC
NOrrTH
Nanaimo, BC
Can an A body make good use of a BB? I know first hand how hard they can pull with a strong 340. So are the A bodies just too light to put the BB torque to the ground, especially with the extra 150lbs on the nose give or take? I asked this question in another post and a poster said wait for the results of the totally stock drags. I looked and couldn't find the stats. Some stats I did see the cars were in the 14s They seemed to be apples and oranges all over the map. Give both cars headers, intake, cam, carbs and good WIDE tires. Its ridiculous having all that power with no where to go on stock pizza cutter tires. Ya I know, there's a Hemi RR FAST guy in the 10's on those things.
'71 GTX N96 auto 3:55
'74 Challenger 440+6 4spd 4:10
'71 Duster 340 auto 4:10
Re: School me - BB vs SB in an A body
[Re: NOrrTH]
#1508498
09/27/13 05:49 PM
09/27/13 05:49 PM
Posts: 4,950 WI
Dcuda69
WI
[Re: NOrrTH]
#1508500
09/27/13 06:21 PM
09/27/13 06:21 PM
Posts: 735 New York
R/T1968R/T
New York
Big block fits like a glove. Big block parts are cheap. A mild BB with stock heads and stroke...easy 12 sec car. Go to Bigblockdart.com easy swap
[Re: Dcuda69]
#1508503
09/27/13 06:58 PM
09/27/13 06:58 PM
NOrrTH
Nanaimo, BC
I think a lot has to do with what you're using the car for. I have a 470"BB in a 69 B'cuda with a 4spd. Aluminum heads,intake waterpump, radiator,etc really help keep weight off the front. I did the disc brake conversion with big bolt wheels. Added frame connectors and front/rear sway bars from Hellwig. So it drives great....goes around corners OK and oh yeah, it does this really good Big block torque in a little package can be a lot of fun!
That's exactly the car I had in mind. Now how would the equivalent 340 go, same mods.
The real reason I'm asking is because I had a very strong 340 Duster and 440 6pk Chally. They were both very fast street cars and people would always ask me which one was faster, and I'd say I'm not sure. With four people in each car, the Chally hands down but one in each?
They make power so differently. The Chally will smoke em through 3 gears but the Duster would spin a little, bite and fly.
[Re: AndyF]
#1508509
09/27/13 09:34 PM
09/27/13 09:34 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
I went from the basically stock 273-904-7 1/4 in my dart to a bone stock (minus fender well headers) low compression 440-727 8.75 both setups had 2.76 gears. It was gonna get a mild 340, but I fell into the big block and all the conversion parts for under $350 from the trans forward. Car is a nose heavy pig with the big block, well was...havent driven it since all the fiberglass parts got put on. I will say the car is a riot even with the low(no)compression 440. If I had to do it over again....Id still go with the 440.
[Re: AndyF]
#1508510
09/27/13 10:15 PM
09/27/13 10:15 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
It is fairly easy to build a 650 hp SB these days so that pushes the bar up on the big block swaps. You need about 700 hp with a big block to make up for the extra weight so that puts you into a fairly serious engine build.
Yup.
As for me, running mid 12's in a small block A-body (that is NOT that light at 3,430 pounds) is a hoot.
[Re: dustergirl340]
#1508511
09/27/13 10:45 PM
09/27/13 10:45 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Yup.
Tell me about that mega dollar SB you got in that car Katherine...
[Re: NOrrTH]
#1508512
09/27/13 10:57 PM
09/27/13 10:57 PM
RapidRobert
With a BB you'd want as much aluminum (intake/HEADS/mc/rad/wp/rims) etc to cut the weight. big decision would be exhaust (HP manifolds/max wedge manifolds/headers). Headers cause front tire problems. May or not want to tub it for more tread. A SB would be less weight from the getgo so less $$$ aluminum needed but you end up with a small big block (only 408 cubes) but goood alum heads would make up for that & make a killer (SB) package. As said good info has been provided & many ways to go. Do checkout www.bigblockdart.com & ask them the same Q . My vote BIG BLOCK
[Re: RUNCHARGER]
#1508516
09/28/13 04:54 PM
09/28/13 04:54 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
I just don't get the BB-A body deal. There's lots of them out there and some of them are quite fast but a nice, Small Block A-body impresses me more. The A-engine cars handle better and don't have header hassles either. Sure you can put aluminum bits on the BB but you can do the same on a small block too. The 340 and 360 based A-bodies just flatout work. I do believe the traction deal is part of it as well.
Sheldon
It's very simple for me. I will never build a wild engine. I want something that will idle smooth well below 1,000 rpm. I don't need the fastest car around, either. BUT, I want a car with lots of torque that handles reasonably well.
Given those parameters, a mild 440 A-body is a blast and easy to build. I've got a stock 340 A-body and I really do like it, but there's nothing like rolling in a little throttle and setting you back in the seat. And, I can make this car handle well enough to be predictable and stable out on the highways.
