Quote: It is fairly easy to build a 650 hp SB these days so that pushes the bar up on the big block swaps. You need about 700 hp with a big block to make up for the extra weight so that puts you into a fairly serious engine build.
Yup.
As for me, running mid 12's in a small block A-body (that is NOT that light at 3,430 pounds) is a hoot.
Tell me about that mega dollar SB you got in that car Katherine...
