Page 1 of 3 1 2 3
Correct 15" Rallye Wheel Trim Rings? Where ? #1508458
09/27/13 04:58 PM
09/27/13 04:58 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
So the Wheel Vintiques series 56 wheels look really nice but their Polished trim rings (Part # 3003-P) look nothing like the originals. They are about 3/8" shallower, they look chrome, not polished and detail on the outer edge is no where near as sharp. Does anyone have a source for a more correct looking part? My car is a '70 so I believe Polished is correct for the 15" wheel but the chrome looks wrong. Thoughts? Thanks, Mike
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: MCTPhoenix] #1508459
09/27/13 09:35 PM
09/27/13 09:35 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
No one. You have to look for good used and have them refurbished. No one has ever reproed the trim rings correctly.
Sheldon
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: RUNCHARGER] #1508460
09/27/13 10:50 PM
09/27/13 10:50 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Who does restoring of these rings?
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: MCTPhoenix] #1508461
09/28/13 11:49 AM
09/28/13 11:49 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here are 2 possible choices that may be "more correct looking". I am not familiar with the details of an original ring.
This thread has a link to rings that the poster says do not leave a gap. https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
Here is a pic of a Specialty Wheels ring on 15x7 magnums/road wheels. I assume the gap would be the same on a 15x7 rallye.
http://www.specialtywheel.com/accessories/trim-rings/trim-ring-15x7.html
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: moparfan53] #1508462
09/28/13 12:02 PM
09/28/13 12:02 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
In the same vein, who makes a good fitting trim ring for a 15" cop wheel?
Anyone have pic?
I know Wheel Vintiques has trim rings they say fit but I'd like to see them on a wheel first, if possible.
Thanks, Joe
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: MCTPhoenix] #1508463
09/28/13 12:10 PM
09/28/13 12:10 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
... My car is a '70 so I believe Polished is correct for the 15" wheel but the chrome looks wrong. Thoughts? Thanks, Mike
FWIW, the parts book just says "chrome".
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: thehemikid] #1508464
09/28/13 12:24 PM
09/28/13 12:24 PM
Canada
Seventythree Offline
Canada
Rick Miller rkmiller@infowest.com
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: moparfan53] #1508465
09/30/13 02:36 PM
09/30/13 02:36 PM
Phoenix, AZ
Phoenix, AZ
I'm ordering a "brushed" wheel vintiques trim ring from Summit to replace the "polished" to compare. I've also ordered a set from LMC Truck based on the feedback in the above thread from 2012. I'll report back and post some pics of the differences. Thanks everyone... Mike
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: MCTPhoenix] #1508466
09/30/13 03:08 PM
09/30/13 03:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The brushed ring is for 71 and later.Also the brushed ring from Vintiques looks like crap. It looks like it was done with 80 grit sand paper, and the factory ones looked like 380 or 400.Also the originals were polished on the lip where the Vintiques are brushed. I sent mine back and got polished ones, and I'm gonna spin them on a wheel and brush them myself.
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: Seventythree] #1508467
09/30/13 03:57 PM
09/30/13 03:57 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Is he in Canada or US?
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: MCTPhoenix] #1508468
09/30/13 04:05 PM
09/30/13 04:05 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Great! It will interesting to see how they compare.
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: thehemikid] #1508469
10/01/13 09:02 AM
10/01/13 09:02 AM
Canada
Canada
Rick Miller is in the US
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: MCTPhoenix] #1508470
10/01/13 11:47 AM
10/01/13 11:47 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I ordered a set fro LMC Truck last year and promptly sent them back.
Absolute JUNK!!!
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: RJS] #1508471
10/01/13 01:36 PM
10/01/13 01:36 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Absolute JUNK!!!
Could you possibly elaborate on the word "junk"?
Did they not fit,look right, What?
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: drew72] #1508472
10/01/13 07:20 PM
10/01/13 07:20 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
You could cut you hands on the sharp edges. Plus they had that brownish look to them, not a clear polished color. There customer service was great and took them back without issue. IE JUNK
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: RJS] #1508473
10/08/13 09:03 PM
10/08/13 09:03 PM
Phoenix, AZ
Phoenix, AZ
OK, after having the Wheel Vintiques Brushed and Polished versions in front of me with the set from LMC truck I decided to keep the LMC truck ones. The wheel vintiques Polished ones looked like cheap chrome, the coloring didn't look "right" and they lacked the final "body line" where the trim ring changed from the edge going down toward the center of the wheel. Their Brushed ones also lacked the "body line" detail and looked like they were sanded with 100 grit paper. BOTH of the wheel vintiques rings also had very poor definition of the stamped ridge at the outer lip... like the die used to stamp them had problems. The LMC parts had that last bodyline stamped in which was just a radius in the WV parts, the lines of the stamping were crisp and not deformed like the WV parts and the coloring was a little better, IMO. They're not perfect, but they were closer than the others. Now; I'll throw a monkey wrench into the works. A friend of mine bought repro rallys and trim rings from WV several years back. His trim rings, in WV boxes, look like LMC stampings, with the extra, last bodyline in it. I tried capturing the coloring and definition of the stamping with my phone camera but was unable to do so.
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: MCTPhoenix] #1508474
10/08/13 10:24 PM
10/08/13 10:24 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
An original as reference. 1
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: cudaized] #1508475
10/08/13 10:25 PM
10/08/13 10:25 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
An original as reference. 2
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: cudaized] #1508476
10/08/13 10:58 PM
10/08/13 10:58 PM
Long Island, NY
shakerjoe Online tonguue
shakerjoe  Online Tonguue
Long Island, NY
these sold a few nights ago - I missed them - http://r.ebay.com/DgsBCO good price I thought...
Re: Correct 15" Rallye Wheel Trim Rings? Where ? [Re: shakerjoe] #1508477
10/09/13 12:00 AM
10/09/13 12:00 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
not a bad price for factory 6 1/2" trim rings... correct factory 7 inch ones would be plenty more.
Page 1 of 3 1 2 3
