Flipping Spring Shackles #1508210
09/26/13 11:15 PM
09/26/13 11:15 PM
Arizona
69rrgrabber Offline OP
Arizona
In an attempt to lower a 69 Charger in the rear, I was thinking of flipping the rear leaf spring shackles. Has any one tried this and does it alter the rear end geometry any? These are the factory stock 440 springs which I have apart and am about to install.
Car has a dana 60, pinion snubber, auto , 440.
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Flipping Spring Shackles [Re: 69rrgrabber] #1508211
09/26/13 11:20 PM
09/26/13 11:20 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Yes and Yes,
My 73 charger I had to grind holes a little bit but I lost Almost 2" and about 1 1/2º of pinion angle.
Well worth it, Ill try to find before and after pics just a minute.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Flipping Spring Shackles [Re: 69rrgrabber] #1508212
09/26/13 11:23 PM
09/26/13 11:23 PM
AndyF Offline
AndyF  Offline
You don't need to hog out the holes in the frame if you buy spring hangers with the second eye hole.
Re: Flipping Spring Shackles [Re: 69rrgrabber] #1508213
09/26/13 11:24 PM
09/26/13 11:24 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The spring hangers have a 4 bolt pattern. The top 2 bolts are closer together than the bottom 2, so the bracket flip is not a direct swap. I've seen some hog out the mounting holes, but to me that seems cheesy and unsafe. Add to this the fact that this alters the pinion angle of the differential. You may end up with a vibration that you didn't have before. I would really suggest that you do not alter the mounting holes.
This is the part where I have to suggest that you have the leaves REarched or to just use a lowering block.
One idea that might be a better way: Check out the spring hangers from AR Engineering. They bolt in like stock but have 2 mounting holes to allow different ride heights.
Re: Flipping Spring Shackles [Re: Kern Dog] #1508214
09/26/13 11:39 PM
09/26/13 11:39 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
If you dont plan on flipping them back there is nothing cheesy about it, the hanger CANT move because you widen two holes and narrow two holes, NO WAY for it to move. Of course it modifies the pinion angle what would be cheesy is if you didnt check your pinion angle if you came up with vibration or weren't for sure.
Now that being said the Purchase products will work great without modifying the car, but they will still mod your pinion angle regardless.
Re: Flipping Spring Shackles [Re: kilroy] #1508215
09/26/13 11:49 PM
09/26/13 11:49 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Sorry man I dont have any really good previous pictures to compare the two mods and an after pic wouldnt do you much different because of the year difference but anyways it was worth it and cheap but everyone brings up good points... It wont look cheesy that I can say for sure. Most of our street cars need a little drop to get the wheels into the fenders slightly.
Re: Flipping Spring Shackles [Re: kilroy] #1508216
09/27/13 03:19 AM
09/27/13 03:19 AM
Arizona
Arizona
I completely forgot that the studs are spaced differently. I don't want to alter the bolt holes for this and will look at the aftermarket parts. Is there any mod that can lower the car without changing the pinion angle?
Thanks,
Re: Flipping Spring Shackles [Re: 69rrgrabber] #1508217
09/27/13 08:57 AM
09/27/13 08:57 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I used SS springs on my 70 when I built it. With the 30 in tall back tires the car just set too high for me. I used the 2 hole front spring hangers and lowered it that way and it still wasn't enough. I ended up installing a pair of 1 1/2" lowering blocks too. I'm happy with the end result. Lowering blocks will not change the pinion angle but it is also a crutch. Best thing to do is have the springs arched to give you the ride height you want without changing all the factory settings. Its all in what you want to spend and how you want it to perform.
...FAFO...
Re: Flipping Spring Shackles [Re: 69rrgrabber] #1508218
09/27/13 09:06 AM
09/27/13 09:06 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I flipped mine many years ago.....zero issues. The pinion angle will have to be checked and probably shimmed(mine needed shims).
