74 Roadrunner Front End kit ordering? #1508205
09/26/13 11:15 PM
09/26/13 11:15 PM
USA
ramairthree Offline OP
USA
getting asked if for press in or screw in ball joints,
why would they come both ways for same year/model?
Thank you.
Re: 74 Roadrunner Front End kit ordering? [Re: ramairthree] #1508206
09/27/13 12:10 PM
09/27/13 12:10 PM
md
mopars4ever Offline
mopars4ever  Offline
md
most likely press in for 74. take a look at your old ones and see if the ball joint end is round or has a nut like end for removal. if i remember correctly 73 was the year they switched from screw in to press in.
Re: 74 Roadrunner Front End kit ordering? [Re: ramairthree] #1508207
09/27/13 03:23 PM
09/27/13 03:23 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
I believe the 74's have press-in lower BJ's and screw in upper BJ's. Mine is a Dec build and it that's the way it is. 73 may be the changeover year with the lowers being either screw-in or pressed... The 73 and 74 upper ball joints are screw-in.
Re: 74 Roadrunner Front End kit ordering? [Re: Runnin74] #1508208
09/27/13 04:06 PM
09/27/13 04:06 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Yep, I was assuming he was talking about the lowers since I had ran into the same problem a few years ago. I should been more clear.
Re: 74 Roadrunner Front End kit ordering? [Re: mopars4ever] #1508209
09/27/13 08:00 PM
09/27/13 08:00 PM
USA
USA
Thank you guys.
