440 Pistons? Where to buy? #1507907
09/26/13 01:23 PM
09/26/13 01:23 PM
MO, USA
The Dodge Guy Offline OP
MO, USA
I am building a 440 and I am having a hard time finding pistons. Where is the best place to get them and who has the best prices? It is just going to be a mild street engine. Thanks for the help.
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507908
09/26/13 01:28 PM
09/26/13 01:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Doubt you could beat Summit for price, maybe try Rock Auto if you are just looking for something in the 9-10:1 range. You don't need anything fancy. What else do you need? Places like Summit, PAW and Jegs sell complete engine kits;
http://www.summitracing.com/search/part-...Order=Ascending
Coming soon!!!!
Re: 440 Pistons? Where to buy? [Re: Mr.Yuck] #1507909
09/26/13 01:56 PM
09/26/13 01:56 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Summit, Jeg's, Competition Wedge & others here, 440Source. I've probably bought from all. Got a killer deal a while back from 440Source, and they also list a lot of info/specs on their website.
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507910
09/26/13 02:38 PM
09/26/13 02:38 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm not sure what your building. Here are several near zero deck pistons (compression height of 2.06+.)
Sealed power makes a lighter weight version of the Forged 6-Pack L2355 piston called the LW2355 ($410/set from Summit.) On TRWs web site it says the LW piston also uses 1/16" ring pack compared to the L2355 pistons 5/64" rings.
The Hypereutectic piston H143CP is also nice if you don't need a forged piston, and it is only $338/set from Summit.
Keith Black has some Hypereutectic pistons in Flat top (KB237 $442/set), or step head for open chamber heads (KB236 $454/set), but the step head pistons usually require a bit more machining to set the quench height correctly. They also have a domed piston for higher compression ratios (KB363L/R Summit lists them individual Left/Right for $81.97 each = $655/set.)
Re: 440 Pistons? Where to buy? [Re: 451Mopar] #1507911
09/26/13 03:03 PM
09/26/13 03:03 PM
MO, USA
MO, USA
I guess I should have said I was looking for .060 over pistons. The machine shop has already rough bored the block to be .060 over. I have been looking on line for them and have really only found .055 over. Thanks again for the help.
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507912
09/26/13 03:17 PM
09/26/13 03:17 PM
dogdays Offline
dogdays  Offline
This is an oops! moment. Didn't see the words "sonic check" anywhere in your posts. Before I bought pistons I'd check and make sure your block is going to hold up. Better to waste the block prep money than to waste block prep AND piston money!
If you're spending $400 or more on run-of-the-mill pistons, throw another couple of hundred in the pot and you can get a semi custom piston that fits your needs. Diamond comes to mind. It usually doesn't cost a lot to make a simple change to a shelf stock piston.
To look at a lot at once, try www.flatlanderracing.com or www.campbellenterprises.com.
For example, I found that Probe and KB make 440 pistons in 0.060 over.
Then I'd suggest buying from a board member who is a dealer.
R.
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507913
09/26/13 03:20 PM
09/26/13 03:20 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Yep, been there. Got a .058 over block & almost all pistons are .055 over as you mentioned. Ended up putting the block under the bench. Speed pro has one as mentioned above but you're going to have to hone it out a little for clearance. Also they way a ton. Not any lighter than the originals. I bought 'em, weighed 'em & immediately sent them back. It was somewhere in the 1125-1150 gram range with pin, I believe.
Honestly, I would get a set custom made if you're set on using that block. That way you can get the skirt clearance you need without the weight of the junk Speed Pros. Some guys don't charge too much extra just the wait time.
Oh ya & even if there is a listing for a .060 piston chances are it's not on the shelf at the manufacturer. Called them all back in may-june. They rarely run that piston/size, once a year or some b.s.
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507914
09/26/13 04:04 PM
09/26/13 04:04 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think most of those I posted can be bought in 0.060 over, plus the Probe pistons, KB ICON, and Ross. What heads and compression ratio are you looking at using?
Custom pistons can be bought, but check around on the cost because some can get over $1,000/set.
The list I used above was when researching low cost pistons for a mild street engine.
I think the 440 source pistons are KB ICON brand, but for aftermarket rods with a 0.990" pin.
Re: 440 Pistons? Where to buy? [Re: 451Mopar] #1507915
09/26/13 04:37 PM
09/26/13 04:37 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Oh they list 'em but don't usually stock them, manufacturer that is. I called Probe, JE, KB etc. when I was looking & they all said they only run them once in awhile. Also have to ask the actual skirt measurement with each manufacturer as they differ. Don't have my notes with me but just a warning on that as they all have different skirt numbers.
Re: 440 Pistons? Where to buy? [Re: 80fbody] #1507916
09/26/13 05:07 PM
09/26/13 05:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Get in touch wit ha Diamond WD and get a semi custom , it's only a small upcharge if you go with a shelf stock piston , tell them where you want the pin and what your bore size is and you are all set . I'm going to be doing a 4.365 bore piston in the near future, same boat as you the bores cleaned up at that size .
Re: 440 Pistons? Where to buy? [Re: JohnRR] #1507917
09/26/13 06:22 PM
09/26/13 06:22 PM
yellow70charger Offline
I bought 60 over from summit they were the sealed power speed pro six-pack pistons. L2355F .060
Re: 440 Pistons? Where to buy? [Re: yellow70charger] #1507918
09/26/13 06:51 PM
09/26/13 06:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think they forged those from lead ...
Re: 440 Pistons? Where to buy? [Re: JohnRR] #1507919
09/26/13 08:49 PM
09/26/13 08:49 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
These guys list some..
http://www.northernautoparts.com/ECatalo...Submit=Continue
Doubt I would use them at that price....for that money(plus a little) you could come up with something much better(lighter)
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507920
09/26/13 09:36 PM
09/26/13 09:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I would spend a little more for the Probe pistons. It is a good entry level performance piston at a good price IMO.
Re: 440 Pistons? Where to buy? [Re: BSB67] #1507921
09/27/13 08:15 AM
09/27/13 08:15 AM
MO, USA
MO, USA
Thanks for all of the replys.
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507922
09/27/13 10:17 AM
09/27/13 10:17 AM
Missouri
3
3_RTs Offline
3_RTs  Offline
Missouri
Thanks, Dodge Guy, for the post. I'm doing the same thing right now--looking for a .060 over piston.
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507923
09/27/13 10:30 AM
09/27/13 10:30 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 440 Pistons? Where to buy? [Re: The Dodge Guy] #1507924
09/27/13 10:32 AM
09/27/13 10:32 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 440 Pistons? Where to buy? [Re: Dodgem] #1507925
09/27/13 10:41 AM
09/27/13 10:41 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Summit has good prices plus friendly website that let's you choose the specs and it will show all your choices. Looks like good prices on probe and icon pistons that are good compression height.
