Holley 50 cc pump install #1507608
09/25/13 05:52 PM
09/25/13 05:52 PM
ont,canada
mopartuner Offline OP
ont,canada
Put a 50 cc pump on my 850 ultra hp carb to try and cure a secondary stumble and just wanted to know if there is pump cams that are 50 cc pump specific?The kit came with 2 cams,a red one that fits and a biege one that the diameter is way off.I have all the other cams for a 750 dp that I have been using up to this point.I changed the pump arm with this install.
410 pump gas solis flat tappet cam 10.95 so far
Re: Holley 50 cc pump install [Re: mopartuner] #1507609
09/25/13 06:22 PM
09/25/13 06:22 PM
Did you use and change the pump arm to the one for the 50 CC pumps? If not you need to do that first before selecting the pump cam. I have removed the 50 CC pumps and arms from all of my double pumper carbs. that came with them stock to cure bogs, stumbles and flat spots when going to WOT I found the off idle stumble and bog on the starting line to be cause by being to rich What size squirters and motors size and intake are you tuning with now ?
Re: Holley 50 cc pump install [Re: Cab_Burge] #1507610
09/25/13 06:32 PM
09/25/13 06:32 PM
ont,canada
ont,canada
I have a 410 10.5 to 1 with the 850 on top of a 2 inch open spacer.The cam is 602/624 262/274 @ .050 installed at 104 deg.I have allready changed HS air bleeds,emulsion bleeds,played with 31/35/37 ssquirters,pump cams and the thing still has a huge stumble when going to WOT.I have a wideband in the car and the idle is good and after it does its stumble it goes good and the afr is at 12.9.The transition from cruise to power is crap.
Re: Holley 50 cc pump install [Re: Cab_Burge] #1507611
09/25/13 06:34 PM
09/25/13 06:34 PM
ont,canada
ont,canada
Oops forgot the intake is a victor
Re: Holley 50 cc pump install [Re: mopartuner] #1507612
09/25/13 11:49 PM
09/25/13 11:49 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run 50cc pumps on my 850's. the one on my Chevy 406 is really responsive. The one on my road runner is still getting dialed in but I know it's going to be fine after I fix the breaks and can tune it a little.
My Chevy has the dark red (maroon) looking one and the screw is in the bottom hole
Not sure on the RR. It's dirty lol
I don't run power valves or vacume advance on either lol
Re: Holley 50 cc pump install [Re: mopartuner] #1507613
09/26/13 01:36 AM
09/26/13 01:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Lets go back to the basics here.. whats your timing at,
if you use advance whats the basic timing and your
total(timing has to be right FIRST before messing with
the carb) then is the pump arm touching the cam on the
accelerator pump... as soon as the throttle moves you
need pump shot
Re: Holley 50 cc pump install [Re: MR_P_BODY] #1507614
09/26/13 05:37 AM
09/26/13 05:37 AM
ont,canada
ont,canada
need pump shot
The timing is set at 14@idle and 32 deg totat all in at 2000 rpm.The pump arm is good.The car ran well with the 750 on it but I think it has more with this 850.The transition from cruise to WOT is garbage.AFR flashes to lean and the car goes silent when you mash the gas.
Re: Holley 50 cc pump install [Re: mopartuner] #1507615
09/26/13 06:25 AM
09/26/13 06:25 AM
Q
Quicktree Offline
Quicktree  Offline
Q
need pump shot
The timing is set at [Email]14@idle[/Email] and 32 deg totat all in at 2000 rpm.The pump arm is good.The car ran well with the 750 on it but I think it has more with this 850.The transition from cruise to WOT is garbage.AFR flashes to lean and the car goes silent when you mash the gas.
what are you working on? timing is low?
Re: Holley 50 cc pump install [Re: Quicktree] #1507616
09/26/13 07:56 AM
09/26/13 07:56 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I know it sounds crazy but I had this problem twice before, the first time I ended up drilling out my dominator squirters to .050 and the car started yanking the front tires off the ground.
Second time, the bowl gaskets swelled and blocked part of the hole in the metering block. New gaskets and back to good launches.
Re: Holley 50 cc pump install [Re: mopartuner] #1507617
09/26/13 08:26 AM
09/26/13 08:26 AM
Make sure the bolt on the pump arms diaghrams are adjusted properly, they should squirt immediatily as soon as you move the throttle a tiny bit and they should have .015 clearance at WOT from being bottomed out It also sounds like your transition circuit may be not functioning correctly Check the float level also, make sure fuel is not splashing out of the front vent tube into the carb. flooding it
Re: Holley 50 cc pump install [Re: Quicktree] #1507618
09/26/13 10:01 AM
09/26/13 10:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
need pump shot
I agree... base timing is low for that cam... I would
move base timing up to about 20* and change the advance
so it goes to 32* or more(to me even your total is
a bit low).. but testing will determine the total...
I think that the timing will correct most of your issue
Re: Holley 50 cc pump install [Re: MR_P_BODY] #1507619
09/26/13 05:13 PM
09/26/13 05:13 PM
organ
maximum entropy Offline
organ
50cc pumps have dedicated cams, BUT, you CAN use 30cc cams with 50cc pumps. i do. i drive my car to the track, so my rule is external carb adjustments only. if it gets real cold, i sometimes have to run the 50cc cams, but keeping it JUST rich enough to keep from bogging (you can tell when your r/t gets erratic that you're getting too lean) is fastest. too rich hurts your 60', but can still be consistent enough to be raceable. control the duration of the shot using the combination of cam and squirter size. study your incremental times to figure out what you need to do for any given weather conditions. this all assuming that your timing is dialed properly.
Re: Holley 50 cc pump install [Re: MR_P_BODY] #1507620
09/26/13 05:51 PM
09/26/13 05:51 PM
ont,canada
ont,canada
need pump shot
I value what you are sugesting here,but darn the thing ran pretty good with that timing.Maybe it can run even stronger with the dizzy locked out,that is the easyest for me to do.I run the MSD pro-billet dist.I allready have the largest bushing and the lightest spring in it.I am going to try it I guess,I have tried everything else.
Re: Holley 50 cc pump install [Re: mopartuner] #1507621
09/26/13 07:50 PM
09/26/13 07:50 PM
ont,canada
ont,canada
I locked the timing at 34 deg and with the 50 cc pump and 37 squirters it still has a stumble when you floor it.AFR goes all the way to the lean end and the motor goes silent........This Holley 850 Ultra carb is a worthless pile of junk,dont buy one.
Re: Holley 50 cc pump install [Re: mopartuner] #1507622
09/27/13 03:02 PM
09/27/13 03:02 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
try a smaller IAB and fatten up the Idle you also will probably want to start trying larger squirters also, I am finding that out with the E-85 conversion and a 1050 dominator that it wants ALOT of fuel at the hit to the tune of .059 squirters at Norwalk in the cool air.Oh, I used the E-85 deal as an example as I have been tinkering to get it dialed in also.
Re: Holley 50 cc pump install [Re: mopartuner] #1507623
09/27/13 04:55 PM
09/27/13 04:55 PM
Call Holley and have them send you a "Call Tag" so they can look at it and fix it for you I'm assuming you bought it new and haven't modified the heck out of it Have you If you bought it used and it has been worked on by someone other than Holley, good luck
Re: Holley 50 cc pump install [Re: Cab_Burge] #1507624
09/27/13 06:16 PM
09/27/13 06:16 PM
ont,canada
ont,canada
I bought this carb new.I even call Holley and told them all the info on the motor and car and they told me that the 850 ultra should be the carb of choice.I have called them many times and they allways say they will call me back and never do.This is the last holley carb I will ever buy.
