Holley 50 cc pump install
#1507608
09/25/13 05:52 PM
09/25/13 05:52 PM
Posts: 614 ont,canada
mopartuner
ont,canada
Put a 50 cc pump on my 850 ultra hp carb to try and cure a secondary stumble and just wanted to know if there is pump cams that are 50 cc pump specific?The kit came with 2 cams,a red one that fits and a biege one that the diameter is way off.I have all the other cams for a 750 dp that I have been using up to this point.I changed the pump arm with this install.
410 pump gas solis flat tappet cam 10.95 so far
Re: Holley 50 cc pump install
[Re: Cab_Burge]
#1507610
09/25/13 06:32 PM
09/25/13 06:32 PM
mopartuner
ont,canada
I have a 410 10.5 to 1 with the 850 on top of a 2 inch open spacer.The cam is 602/624 262/274 @ .050 installed at 104 deg.I have allready changed HS air bleeds,emulsion bleeds,played with 31/35/37 ssquirters,pump cams and the thing still has a huge stumble when going to WOT.I have a wideband in the car and the idle is good and after it does its stumble it goes good and the afr is at 12.9.The transition from cruise to power is crap.
[Re: mopartuner]
#1507613
09/26/13 01:36 AM
09/26/13 01:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Lets go back to the basics here.. whats your timing at, if you use advance whats the basic timing and your total(timing has to be right FIRST before messing with the carb) then is the pump arm touching the cam on the accelerator pump... as soon as the throttle moves you need pump shot
[Re: mopartuner]
#1507615
09/26/13 06:25 AM
09/26/13 06:25 AM
Quicktree
The timing is set at [Email]14@idle[/Email] and 32 deg totat all in at 2000 rpm.The pump arm is good.The car ran well with the 750 on it but I think it has more with this 850.The transition from cruise to WOT is garbage.AFR flashes to lean and the car goes silent when you mash the gas.
what are you working on? timing is low?
[Re: Quicktree]
#1507618
09/26/13 10:01 AM
09/26/13 10:01 AM
MR_P_BODY
I agree... base timing is low for that cam... I would move base timing up to about 20* and change the advance so it goes to 32* or more(to me even your total is a bit low).. but testing will determine the total... I think that the timing will correct most of your issue
[Re: MR_P_BODY]
#1507619
09/26/13 05:13 PM
09/26/13 05:13 PM
Posts: 5,080 organ
maximum entropy
organ
50cc pumps have dedicated cams, BUT, you CAN use 30cc cams with 50cc pumps. i do. i drive my car to the track, so my rule is external carb adjustments only. if it gets real cold, i sometimes have to run the 50cc cams, but keeping it JUST rich enough to keep from bogging (you can tell when your r/t gets erratic that you're getting too lean) is fastest. too rich hurts your 60', but can still be consistent enough to be raceable. control the duration of the shot using the combination of cam and squirter size. study your incremental times to figure out what you need to do for any given weather conditions. this all assuming that your timing is dialed properly.
[Re: mopartuner]
#1507621
09/26/13 07:50 PM
09/26/13 07:50 PM
mopartuner
ont,canada
I locked the timing at 34 deg and with the 50 cc pump and 37 squirters it still has a stumble when you floor it.AFR goes all the way to the lean end and the motor goes silent........This Holley 850 Ultra carb is a worthless pile of junk,dont buy one.
[Re: mopartuner]
#1507622
09/27/13 03:02 PM
09/27/13 03:02 PM
dartman366
Mt. Vernon, Ohio
try a smaller IAB and fatten up the Idle you also will probably want to start trying larger squirters also, I am finding that out with the E-85 conversion and a 1050 dominator that it wants ALOT of fuel at the hit to the tune of .059 squirters at Norwalk in the cool air.Oh, I used the E-85 deal as an example as I have been tinkering to get it dialed in also.
