70 340 engine ground strap #150731
11/14/08 12:35 AM
11/14/08 12:35 AM
Anonymous OP
Anonymous OP
What is the difference between a 1969 340 engine ground strap and 1970 340 engine ground strap? I see several places selling the 1969 part, but cannot find a 1970 340 ground strap.
Any help would be appreciated.
Thanks,
Jason
jgalaske@comcast.net
Re: 70 340 engine ground strap #150732
11/14/08 12:56 AM
11/14/08 12:56 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I can not comment on the 1969 version, but for 1970 the negative battery cable terminal had two leads.
One lead (the larger wire) went to the driver's side cylinder head.
The second lead (smaller wire) went to body ground.
Re: 70 340 engine ground strap [Re: Alaskan_TA] #150733
11/14/08 07:43 AM
11/14/08 07:43 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
69 used a ground strap from the back of the head to the fire wall.
Re: 70 340 engine ground strap [Re: Alaskan_TA] #150734
11/14/08 08:07 AM
11/14/08 08:07 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
by attaching to the radiator support for the body ground
Re: 70 340 engine ground strap [Re: gtx6970] #150735
11/14/08 09:23 AM
11/14/08 09:23 AM
Anonymous OP
Anonymous OP
the only STOCK ground strap ive ever seen on a 70 340 is the battery cable. big cable bolts to the front of drivers side head and goes to - battery post. At the battery post, a smaller cable comes out and goes to the radiator support.
Ive never seen a STOCK ground strap to the firewall. I put one in on mine but I know it is NOT original
Re: 70 340 engine ground strap #150736
11/14/08 12:26 PM
11/14/08 12:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
duh, brain fart - fixed now
