Evapo rust? Who uses it? #1506944
09/24/13 04:54 PM
09/24/13 04:54 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Seen different guys post saying they used it. What's everyone's views on it? Looking at seeing where I can get it to do things that I don't want to sandblast like head light buckets and small things. Where do you buy it at? Called my jobber but they don't carry it. How's it sold? Gallons? How far does it go if you are soaking items?
Contact Me about AMD Prices
Re: Evapo rust? Who uses it? [Re: hotairballoonpilot] #1506945
09/24/13 05:15 PM
09/24/13 05:15 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
It works great for lighter rust, heavy scale will need to be wire wheeled first and soaked longer. i soaked my 8 3/4 third member and it looked like new when it was done. I can't help you with where to buy it, I get mine from a farm supply store.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Evapo rust? Who uses it? [Re: gregsrt] #1506946
09/24/13 05:20 PM
09/24/13 05:20 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://www.rustremover.net/
You could have used GOOGLE, but here's a link.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Evapo rust? Who uses it? [Re: hemi71x] #1506947
09/24/13 05:28 PM
09/24/13 05:28 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
I have not used it but you can buy it at Harbor Freight
http://www.harborfreight.com/catalogsearch/result?q=evapo+rust
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Evapo rust? Who uses it? [Re: loco340cuda] #1506948
09/24/13 06:20 PM
09/24/13 06:20 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Stuff works great. I've used it alot on small stuff like nuts and bolts.
Re: Evapo rust? Who uses it? [Re: rallye73] #1506949
09/24/13 06:28 PM
09/24/13 06:28 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I use it on smaller stuff, autozone had it on sale for 6.99 a quart.
Re: Evapo rust? Who uses it? [Re: ademon] #1506950
09/24/13 06:41 PM
09/24/13 06:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Ive used Evaporust and another product, Safest Rust Remover. Both work excellent to remove rust (any amount, thick or thin) the time you need to submerge it varies withe amount of rust. In a side by side test the www.safestrustremover.com won the battle on cost, the amount of rust a gallon will remove, and ease of use.
Re: Evapo rust? Who uses it? [Re: hotairballoonpilot] #1506951
09/24/13 08:36 PM
09/24/13 08:36 PM
I ain't yet but from the rave reviews it's gotten (on here) it's definitely on my list
Re: Evapo rust? Who uses it? [Re: RapidRobert] #1506952
09/24/13 08:48 PM
09/24/13 08:48 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I just de-rusted my cooling system with it per Scott and looks like it did the trick. Got mine at advance auto. $22 a gallon.
Re: Evapo rust? Who uses it? [Re: Silverbullet2] #1506953
09/24/13 09:06 PM
09/24/13 09:06 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I keep a 5 gallon bucket of Evaporust in my garage at all times. Whenever I have smaller parts that need to be cleaned, I toss them in it overnight. I have been very happy with how it works. I also did my third member in it and cleaned it off with Acetone before I coated it with RPM. I also used it in my ultrasonic cleaner for cleaning up my bolts, screws and fasteners.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Evapo rust? Who uses it? [Re: FJR doc] #1506954
09/24/13 09:11 PM
09/24/13 09:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I did a whole bunch of parts and a pedal car body.
Happy with it. Got it mail order than thru HF.
I'd suggest cleaning any parts first, grease seems to make it less potent.
Re: Evapo rust? Who uses it? [Re: RodStRace] #1506955
09/24/13 09:59 PM
09/24/13 09:59 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct, it won't work through dirt or grease, parts need to be cleaned and degreased first for the best results. This goes for both Evaporust and Safest Rust Remover.
Re: Evapo rust? Who uses it? [Re: ScottSmith_Harms] #1506956
09/25/13 08:53 PM
09/25/13 08:53 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Is there any negative effects to galvanized steel?I have a ashtray and headlight baskets to do.Using evaporust on lots of hardware and smaller items with excellent results.
Re: Evapo rust? Who uses it? [Re: crowbait] #1506957
09/26/13 11:48 AM
09/26/13 11:48 AM
dogdays Offline
dogdays  Offline
I'd say don't use it on galvanizing unless you want the galvanizing to either turn black or disappear.
Galvanizing deposits a zinc layer on the steel. The zinc corrodes first before the steel does, that's its job. It's called a sacrificial coating. A solution that is supposed to attack rust is probably acidic, so it will oxidize the zinc.
End result, no galvanizing or at least a very hard time getting it to look right.
That's my opinion.
R.
Re: Evapo rust? Who uses it? [Re: dogdays] #1506958
09/26/13 11:54 AM
09/26/13 11:54 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Works well but don`t expect it to last for a long period of time. It turns to crap rather quickly.
Re: Evapo rust? Who uses it? [Re: mopars4ever] #1506959
09/26/13 12:06 PM
09/26/13 12:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct on the galvanizing, it will remove the bond between the base metal and the coating. The reason is simple as explained above, since Evaporust removes corrosion, it removes the corrosion layer that bonds the two materials and they separate. I learned this the hard way, put a mint set of KH A body disc brake backing plates in to clean up some small rust specs and ended up watching all the nice zinc flakes slide off the clean shiny metal underneath when I rinsed them off .....DOH!
Re: Evapo rust? Who uses it? [Re: ScottSmith_Harms] #1506960
09/26/13 12:11 PM
09/26/13 12:11 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Whats the best way to dispose of old evaporust ?
Re: Evapo rust? Who uses it? [Re: JohnRR] #1506961
09/26/13 11:58 PM
09/26/13 11:58 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The Evapo-Rust web site says it is "sewerable" but also says "only the chelated iron content of the solution will dictate disposal requirements". Maybe this means you should filter it before pouring the liquid in the sewer?
I suspect you can filter it by (1) fold a large paper towel twice (2)insert the paper in a funnel (3) pour (4) dispose of paper in trash. (This is also a good way to filter coolant that is to be re-used.)
Interesting that the web site never mentions not to use it on galvanized or zinc plated items. Their lame web site looks to have been written and designed by an ex-used car salesman, not someone knowledgeable about chemistry.
The cheapest price I have found is to order it on line from Northern Tool and pick it up from their store with $0 freight. But next time I'll be trying Safest Rust Remover.
But I will say that Evapo-Rust proved me to be a genius when I hesitated to invest in sandblasting equipment. Sure glad I dawdled.
Re: Evapo rust? Who uses it? [Re: kentj340] #1506962
09/27/13 12:24 AM
09/27/13 12:24 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
FYI, so will Safest Rust Remover. Same chemistry is involved, just a different blend. I have not seen either product harm anything else.
Really, no harm in sending it down the drain as long as you don't mix it with grease, oil, etc. the dissolved rust in it won't harm anything and is non toxic. This is another good reason to clean your parts of grease and oil before derusting them.
