MSD Wiring #1506790
09/24/13 09:13 AM
09/24/13 09:13 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Hey guys, I understand how to wire the MSD box, but my question is are you running your thick power and ground leads directly to the battery per the instructions? I don't like this idea, just looking for ways around this. Why does the box need power when the switch is off? This doesn't cause a drain?
Also, for the secondary power lead, I'm assuming you are running this to the 12V side of the ballast resistor, any trick ways to run this without hacking my harness (new engine harness). I don't particularly like wiring accessories to the 12V side of the ballast either because I burned it up once before.
And lastly, any ideas on bypassing the ballast resistor without hacking the harness?
I have some ideas but just looking for some more.
Re: MSD Wiring [Re: GTX MATT] #1506791
09/24/13 09:32 AM
09/24/13 09:32 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Got any other power points on your car that is supplied by a wire the size of your MSD power wire?
I don't think so? MSD pulls a lot of power at hi rpm, it needs to be run directly to the battery.
Re: MSD Wiring [Re: GTX MATT] #1506792
09/24/13 09:49 AM
09/24/13 09:49 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My battery has the 8mm hex head screw terminals on the side. I wired my MSD directly to these terminals.
Re: MSD Wiring [Re: YO7_A66] #1506793
09/24/13 10:41 AM
09/24/13 10:41 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Mine is hid inside the car. I ran a 10 gauge wire from the MSD to the battery post on the starter relay.
Oh and when I wired mine up the instructions said NOT to use a ballast resistor. I didn't.
Re: MSD Wiring [Re: Silverbullet2] #1506794
09/24/13 12:23 PM
09/24/13 12:23 PM
dogdays Offline
dogdays  Offline
There's some sort of relay inside the box. The small red wire, when energized,, closes the relay and connects the box to the big wire. So the box is really not energized when the car is turned off, or for that matter any time you don't have sufficient voltage on the small red wire.
The Capacitive Discharge ignition does not use a ballast resistor. Leaving the ballast resistor in the feed for the small red wire may cause the relay to malfunction. Get rid of it.
R.
Re: MSD Wiring [Re: dogdays] #1506795
09/24/13 02:46 PM
09/24/13 02:46 PM
California
mickm Offline
mickm  Offline
California
i run mine from the starter relay as well...
Re: MSD Wiring [Re: mickm] #1506796
09/24/13 03:54 PM
09/24/13 03:54 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
As for the ballast resistor, what I do is make a wire that bridges the wiring connectors. That way the BR is bypassed, I don't have to hack the harness, and I can return to stock if I ever want to in the future.
Re: MSD Wiring [Re: topside] #1506797
09/24/13 05:12 PM
09/24/13 05:12 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
This is what I was thinking.
The relay in the box makes me feel better about this/makes sense.
Re: MSD Wiring [Re: GTX MATT] #1506798
09/24/13 06:14 PM
09/24/13 06:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You could take the resistor coil out of the ballast and replace it with a good sized wire so everything looks stock.. Carry a spare ballast in the glove box in case of an MSD failure..
I am truckless..
