MSD Wiring
#1506790
09/24/13 09:13 AM
09/24/13 09:13 AM
Posts: 5,163 CT
GTX MATT
CT
Hey guys, I understand how to wire the MSD box, but my question is are you running your thick power and ground leads directly to the battery per the instructions? I don't like this idea, just looking for ways around this. Why does the box need power when the switch is off? This doesn't cause a drain?
Also, for the secondary power lead, I'm assuming you are running this to the 12V side of the ballast resistor, any trick ways to run this without hacking my harness (new engine harness). I don't particularly like wiring accessories to the 12V side of the ballast either because I burned it up once before.
And lastly, any ideas on bypassing the ballast resistor without hacking the harness?
I have some ideas but just looking for some more.
Re: MSD Wiring
[Re: GTX MATT]
#1506792
09/24/13 09:49 AM
09/24/13 09:49 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
My battery has the 8mm hex head screw terminals on the side. I wired my MSD directly to these terminals.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: MSD Wiring
[Re: YO7_A66]
#1506793
09/24/13 10:41 AM
09/24/13 10:41 AM
Posts: 580 North Carolina, USA
Silverbullet2
North Carolina, USA
Mine is hid inside the car. I ran a 10 gauge wire from the MSD to the battery post on the starter relay.
Oh and when I wired mine up the instructions said NOT to use a ballast resistor. I didn't.
Re: MSD Wiring
[Re: GTX MATT]
#1506798
09/24/13 06:14 PM
09/24/13 06:14 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
You could take the resistor coil out of the ballast and replace it with a good sized wire so everything looks stock.. Carry a spare ballast in the glove box in case of an MSD failure..
I am truckless..
