98 Ram SS/T spindle question #1505595
09/21/13 11:51 PM
09/21/13 11:51 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
It appears that inner race has been spinning on the spindle. There is a groove worn right into the spindle where the inner race rests. Picture is attached. Do I need to shop for new spindles? I replaced all the bearings and I've been using Amzoil grease for years. I follow shop manual wheel bearing adjustment. Any ideas why this happened? I bought this truck at 85K now has little under 120K. I repacked the bearings about 20K ago. Thanx guys.
Re: 98 Ram SS/T spindle question [Re: Gabmando] #1505596
09/22/13 01:33 AM
09/22/13 01:33 AM
State of retirement
52savoy Online content
52savoy  Online Content
State of retirement
I would replace it(or them) I have owned a '98 SST since it was almost new and haven't had that problem
Sometimes parts just wear out
Re: 98 Ram SS/T spindle question [Re: 52savoy] #1505597
09/22/13 10:52 PM
09/22/13 10:52 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Thank you for the response. To tell you the truth that's the advice I expected. Problem is that I'll have to locate a really clean used set. these are discontinued. I found one on the net at about $600. Ouch.
Re: 98 Ram SS/T spindle question [Re: Gabmando] #1505598
09/22/13 11:51 PM
09/22/13 11:51 PM
State of retirement
State of retirement
That's pretty steep. I can get a set for much less than that from a u-pull-it. Any 1500 Ram should be the same
Re: 98 Ram SS/T spindle question [Re: 52savoy] #1505599
09/23/13 12:37 AM
09/23/13 12:37 AM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
Check www.car-part.com in you area for good used ones. Most salvage yards use this site. I have had really good luck with it.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
