75-80 Gauge bezel and radio measurements
#1505536
09/21/13 10:09 PM
09/21/13 10:09 PM
Posts: 3,266 Pyeongtaek, South Korea
69HemiGTX
I need to know the dimensions of the center section of the 75-80 gauge bezel. I'm talking about the part that contains the four gauge cluster, speedo, and radio. I don't really need the rounded ends yet, just the rectangular section. Also, if anyone can, I need the dimensions of the radio faceplate. Not the opening, just the radio itself (the inner silver outline in the pic below). I want remove the idiot lights and move the radio down to make room for gauges above it. I plan on using sheetmetal for the bezel instead of hacking a factory piece. Thanks in advance.
OIF V and OEF X veteran and proud of it!
Re: 75-80 Gauge bezel and radio measurements
[Re: 69HemiGTX]
#1505539
09/22/13 12:28 AM
09/22/13 12:28 AM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
the measurement of a standard DIN slot is 2-1/8” (50mm) height by 7-1/8” (180mm) width. mopars (from the time period you want) have a DIN and a half opening. so, the radio would need the full width of 7-1/8" wide but an installed height of 3-3/16". (180mm X 75mm) looking at yoiur radio, you could always just trace the outline, of the inner chrome surround trim. that seems to be the actual minimum face you could show, if needed. you can also buy DIN and a half mounting plates, and use one to fab up your setup.
[Re: 76dodgeboy]
#1505541
09/22/13 06:54 AM
09/22/13 06:54 AM
69HemiGTX
This is exactly what I want - the absolute minimum space needed. I'd love to measure one myself, but as I said earlier, I'm in Korea.
If your in Korea how are you going to make the dash piece?
I'm not going to make the final piece yet, just a mock-up to see if everything fits right. I'm in Shops Platoon, and one of the shops we have is sheetmetal. I have all the material and equipment I need here. I just need to know the dimensions of the rectangular section so I can see if it's all going to fit. I have full-size printouts of the gauges so I can use them for my layout. If it works, I'll make the whole piece when I PCS back to the States.
[Re: bigblock340power]
#1505543
09/23/13 10:14 AM
09/23/13 10:14 AM
69HemiGTX
I'll fab a bracket for the radio. Nutplates, rivets, and the like are no problem. The sheetmetal shop has tons of them, no matter where I'm stationed. I don't plan on mounting the radio to the new bezel. The gauges will because they'll be Auto Meters, not stock. I've already thought about all of this.
Here's what I would like to have - measurements of the flat, rectangular section of the gauge bezel and the smallest possible opening size for the radio face, both outlined in yellow. I need the measurements quickly because Auto Meter is having a 10% off sale through the end of the month. As expensive as these are, it'll make a huge difference. But I can't order them until I know everything will fit. If I wasn't on the other side of the world, I wouldn't even be asking this.
