360 magnum roller lifters #1505338
09/21/13 11:41 AM
09/21/13 11:41 AM
pa
O
oldschoolracer Offline OP
O
pa
does anybody know who makes solid roller lifters for 360 magnum. seems they are different than la engines.
Re: 360 magnum roller lifters [Re: oldschoolracer] #1505339
09/21/13 01:07 PM
09/21/13 01:07 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
There is a fellow here in La that takes the hyd lifters and makes them into solids so you can use the stock holding gear. We tried to use dif solid lifters but cound not get the clearance needed to work properly. Even tried machining the tops of the lifter bores to do away with the bog-bone holders so the link bars would clear... couldnt come up with a solution. I am waiting on a set of the converted rollers as we speak...
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: 360 magnum roller lifters [Re: oldschoolracer] #1505340
09/21/13 01:19 PM
09/21/13 01:19 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I'm running converted hydraulics.... a buddy of mine "fixed" them. I don't know of any place that's actually making them. I was running Rhoads with them adjusted way down to super-low lash - but they were still noisy.
Re: 360 magnum roller lifters [Re: StandOnIt] #1505341
09/21/13 01:19 PM
09/21/13 01:19 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
sealed power makes them...
way better off with the mopar perf. from Jeg's
