waking the duster up after 3 years down time #1505199
09/20/13 11:39 PM
09/20/13 11:39 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
well this weekend i am going to get it started and heated up. maybe next week i can go to cecil md or maple or numidia pa.
it is a 440 with a stock stroke crank. old indy heads and a 262/265 630 solid. dominator carb.
it would be kool to see 10 teens or 10 Os
Re: waking the duster up after 3 years down time [Re: dmking] #1505200
09/20/13 11:47 PM
09/20/13 11:47 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Pictures?
Re: waking the duster up after 3 years down time [Re: 69CHARGERMD] #1505201
09/21/13 04:25 AM
09/21/13 04:25 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
That's good times for a stock stroke, what does it weigh ?
Last week I took my car out for the first time this year but didn't get a full run due to the fuel pump taking a dump. It was pb weather as well.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: waking the duster up after 3 years down time [Re: deaks] #1505202
09/21/13 12:50 PM
09/21/13 12:50 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
Mine has been sleeping for 4 years, it will. Awaken next year. Good luck buddy.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: waking the duster up after 3 years down time [Re: kingdust] #1505203
09/21/13 04:12 PM
09/21/13 04:12 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
mines been asleep longer than that. I'm going to pull the intake to get to the roller lifters. I afraid they'll be dry. Any other suggestions will be welcome. I will replace all the fuel lines and the new fuel pump with about 15 passes will need help also.
[img] [/img]
Re: waking the duster up after 3 years down time [Re: clonestocker] #1505204
09/21/13 04:19 PM
09/21/13 04:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Bring it to Cecil this Wednsday night as I plan to go then. Ron
Re: waking the duster up after 3 years down time [Re: clonestocker] #1505205
09/21/13 11:12 PM
09/21/13 11:12 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I would fill it with oil and it will all run down to the lifters, hit with a pre oiler and then light it off.
68 Barracuda Formula S 340
Re: waking the duster up after 3 years down time [Re: dmking] #1505206
09/22/13 12:39 AM
09/22/13 12:39 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
After the angry sounds that came from under my car last night when we launched it on the big gun it may be time for it to take a nap...... ahh who am I kidding I'm not that smart
Re: waking the duster up after 3 years down time [Re: SpareParts] #1505207
09/22/13 11:33 PM
09/22/13 11:33 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
started it today. it sounds good. but coolant out of the freeze plug at starter. with hard block in it it is not comming out. got some black stuff to put in to seal it from a friend.
does cecil prep the track on a wednesday night? i know no fast cars for friday night. i may be pushing it to go friday to numidia.
the idle is different from the cam being retarded 2 deg. i was not expecting that.
it ran 10.70s at 104 ran 10.20s at 108 and now it is at 110 so here goes try for best numbers. the day it split it ran a 10.27@ 131.75 with a 1.55 60ft stumble then it split the block next pass on a 1.48 60ft. that should of been in the teens. all same parts except a better stock stroke crank than the 40 year old stocker. well and a different block......
Re: waking the duster up after 3 years down time [Re: dmking] #1505208
09/22/13 11:37 PM
09/22/13 11:37 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
here is a picture if it works
Re: waking the duster up after 3 years down time [Re: dmking] #1505209
09/23/13 05:55 PM
09/23/13 05:55 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Nice car
Re: waking the duster up after 3 years down time [Re: dmking] #1505210
09/23/13 08:42 PM
09/23/13 08:42 PM
K
kingdust Offline
kingdust  Offline
K
sorry to here that, I have a friend that's getting rid of all his BB stuff including a 70 440HP block if your interested.
Re: waking the duster up after 3 years down time [Re: clonestocker] #1505211
09/23/13 09:14 PM
09/23/13 09:14 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
assuming everything else is ok i wouldn't bother doing that. just take some time and do a good priming job. hope the engine was put up properly though.
Re: waking the duster up after 3 years down time [Re: jamesc] #1505212
09/03/14 06:51 PM
09/03/14 06:51 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
well my report is at 3120lb with me in it it went a best of 10.100 at maple grove in about 65degf and a killer 90 humidity.
i upped the timing and it seems the flash went up higher but i would not say it made a et difference.
Re: waking the duster up after 3 years down time [Re: dmking] #1505213
09/03/14 07:11 PM
09/03/14 07:11 PM
In a house near you
Street Monkies Offline
In a house near you
That's nothing to be ashamed of. Thanks for the update !
