2000/1980 rim swap #1504976
09/20/13 03:19 PM
09/20/13 03:19 PM
Gilman, IA
sabbfan Offline OP
sabbfan  Offline OP
Gilman, IA
I have two 3/4 ton pickups, both 4x4, and was hoping I could swap the rims on them. Ones a 2000 V10 and the others a 1980 W200. The '80 has nearly new BF Goodrich all terrains and Cragar soft 8 rims, but I hardly ever drive it. The V10 has stock rims and worn tires, so I was hoping I could just swap rims and tires til I decide to buy new tires. Also hoping someone could tell me if it will work before I go to the effort of jacking the trucks up and wasting half a day to realize one or the other wont fit.
2012 Ram 2500 Crew Cab 4x4 5.7 Hemi
2011 Dodge Durango 3.6L
2009 Dodge Caliber 1.8L 5 speed
1970 Super Bee-someday!
Re: 2000/1980 rim swap [Re: sabbfan] #1504977
09/20/13 05:05 PM
09/20/13 05:05 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yep. They bolt rite on. They'll stick out a little further bit still work. Are the tire sizes close? We run 285/76s on my wife 01 but its only a 1500 so doesn't sit as high as yours. Also the 2000 wheels will fit the 80. My 76 had 94-01 wheels on it. they would rub some at full lock due to offset/backspacing but that's only issue
Re: 2000/1980 rim swap [Re: 76dodgeboy] #1504978
09/21/13 04:26 AM
09/21/13 04:26 AM
Gilman, IA
sabbfan Offline OP
sabbfan  Offline OP
Gilman, IA
Excellent! The tires are the exact same size on both trucks, I was hoping the wheels would swap with no problems.
Re: 2000/1980 rim swap [Re: sabbfan] #1504979
09/22/13 03:11 PM
09/22/13 03:11 PM
Gilman, IA
sabbfan Offline OP
sabbfan  Offline OP
Gilman, IA
Well the cragars off of the '80 fit the 2000, but the aluminum wheels off the 2000 hit the tie rod ends of the 80. Does anyone know if steel wheels off a 94-01 3/4 ton will work instead of the aluminum ones? I have a lead on some steel wheels off of a '99.
Re: 2000/1980 rim swap [Re: sabbfan] #1504980
09/24/13 01:16 AM
09/24/13 01:16 AM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
tryied to put a set of 2000 on my 99 and didnt fit because of the same thing. something about that 2000 year steering i think
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 2000/1980 rim swap [Re: hulmule] #1504981
09/25/13 01:32 PM
09/25/13 01:32 PM
dogdays Offline
dogdays  Offline
The later trucks run wheels with more than 1" more positive offset, it's a hassle to put them on older trucks.
R.
Re: 2000/1980 rim swap [Re: dogdays] #1504982
09/25/13 02:35 PM
09/25/13 02:35 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
R.
My Bad. The newer wheels fit 2wds for sure. I apologize. You can run a spacer.
My 76 was a D200 with steel 94-01 rims. The steel and aluminum will basically be the same dimensions
