2000/1980 rim swap
#1504976
09/20/13 03:19 PM
09/20/13 03:19 PM
Posts: 546 Gilman, IA
sabbfan
Gilman, IA
I have two 3/4 ton pickups, both 4x4, and was hoping I could swap the rims on them. Ones a 2000 V10 and the others a 1980 W200. The '80 has nearly new BF Goodrich all terrains and Cragar soft 8 rims, but I hardly ever drive it. The V10 has stock rims and worn tires, so I was hoping I could just swap rims and tires til I decide to buy new tires. Also hoping someone could tell me if it will work before I go to the effort of jacking the trucks up and wasting half a day to realize one or the other wont fit.
2012 Ram 2500 Crew Cab 4x4 5.7 Hemi 2011 Dodge Durango 3.6L 2009 Dodge Caliber 1.8L 5 speed 1970 Super Bee-someday!
Re: 2000/1980 rim swap
[Re: 76dodgeboy]
#1504978
09/21/13 04:26 AM
09/21/13 04:26 AM
sabbfan
Gilman, IA
Excellent! The tires are the exact same size on both trucks, I was hoping the wheels would swap with no problems.
[Re: sabbfan]
#1504979
09/22/13 03:11 PM
09/22/13 03:11 PM
sabbfan
Gilman, IA
Well the cragars off of the '80 fit the 2000, but the aluminum wheels off the 2000 hit the tie rod ends of the 80. Does anyone know if steel wheels off a 94-01 3/4 ton will work instead of the aluminum ones? I have a lead on some steel wheels off of a '99.
[Re: sabbfan]
#1504980
09/24/13 01:16 AM
09/24/13 01:16 AM
Posts: 1,408 northeast ohio
hulmule
northeast ohio
tryied to put a set of 2000 on my 99 and didnt fit because of the same thing. something about that 2000 year steering i think
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: dogdays]
#1504982
09/25/13 02:35 PM
09/25/13 02:35 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
The later trucks run wheels with more than 1" more positive offset, it's a hassle to put them on older trucks. R.
My Bad. The newer wheels fit 2wds for sure. I apologize. You can run a spacer. My 76 was a D200 with steel 94-01 rims. The steel and aluminum will basically be the same dimensions
