Should I switch to an automatic #1504874
09/20/13 12:16 PM
09/20/13 12:16 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
Hi everybody!
I am considering putting an automatic where the 4 speed lives in my 64 Dodge. The reasoning behind this is hopefully lower maintenance and less parts breakage when bracket racing at GLD. Talk me into, or out of it. If into what sort of stuff does a 727 need to do this keeping in mind I know nothing about automatics.
The car is old school with a 383, ported 906s Torker intake, 750 dp, .557” 296 duration solid DC cam and 4.56s in a 9”. It has run as quick as 12.82 and as fast as 109.5 mph.
Thanks very much for any and all opinions and information.
Tim
Re: Should I switch to an automatic [Re: MadMez] #1504875
09/20/13 12:22 PM
09/20/13 12:22 PM
sweden
sshemi Offline
sshemi  Offline
sweden
What parts are you braking?
It should live long at that hp.
I have been 95 mph in the 1/8 at 3800 lbs with no brakeage.
It will probably run faster with an auto but whats the fun in that?
Re: Should I switch to an automatic [Re: sshemi] #1504876
09/20/13 12:29 PM
09/20/13 12:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What makes you think an auto is cheaper? A GOOD race 727 is going to run you $1200 or more a converter another $500+ Then you'll need a good shifter $200+, trans lines, trans cooler $150 or so... it adds up. What are you breaking and why? at those speeds a 4 speed should be fine.
Coming soon!!!!
Re: Should I switch to an automatic [Re: Mr.Yuck] #1504877
09/20/13 12:53 PM
09/20/13 12:53 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
I have not broken anything since I replaced all the Ford parts in the 9". But now I'm paranoid about it probably for no reason. Your talking me into keeping the 4 speed
Thanks!
Re: Should I switch to an automatic [Re: MadMez] #1504878
09/20/13 01:16 PM
09/20/13 01:16 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Keep the 4-speed!!!
Re: Should I switch to an automatic [Re: dustergirl340] #1504879
09/20/13 01:26 PM
09/20/13 01:26 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Your wardrobe will have to change too. Think of the expense for your high heels and skirts alone!
4speeds can be very consistent. The Autos are just more boring.
Sure if you want to try and win a bunch of money, get rid of some the fun, then put an auto in.
Re: Should I switch to an automatic [Re: LAR_414] #1504880
09/20/13 01:34 PM
09/20/13 01:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW if this cars body was in better shape , it would of had a 4 speed.
Re: Should I switch to an automatic [Re: LAR_414] #1504881
09/20/13 01:39 PM
09/20/13 01:39 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
I'll have you know I would look fabulous in a skirt. My legs are strong and well formed. But thats only because they are responsible for dragging the rest of my fat @ss around.
Re: Should I switch to an automatic [Re: MadMez] #1504882
09/20/13 05:44 PM
09/20/13 05:44 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Four speeds add charisma and make the car a hoot to drive, till the guy with the greaseball 318 and $1200 converter drive past you laughing.
Re: Should I switch to an automatic [Re: MadMez] #1504883
09/20/13 06:06 PM
09/20/13 06:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your good with the shifter then keep the 4 speed
since that is a more efficient way to go... but if you
tend to miss the 2-3 shift(and I'm not talking granny
shifting)... go with the auto
Re: Should I switch to an automatic [Re: MadMez] #1504884
09/20/13 06:15 PM
09/20/13 06:15 PM
Idaho
Runner Offline
Runner  Offline
Idaho
i say if you have a high 12 second 4 speed car and want a more race friendly automatic then keep the 4 speed car and buy a cheap a body. no way would i convert a car from a stick to an auto.
Re: Should I switch to an automatic [Re: Runner] #1504885
09/20/13 06:41 PM
09/20/13 06:41 PM
California
mickm Offline
mickm  Offline
California
i said this in another thread. if tomorrow my only choice was an automatic, i'd sell the road runner and quit the hobby.
if you are breaking parts at that horsepower level, something else is wrong.
Re: Should I switch to an automatic [Re: mickm] #1504886
09/20/13 07:29 PM
09/20/13 07:29 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'd sooner lose with a 4 speed than win with an automatic, especially in a 10 second or slower car. It's about having fun.
Sheldon
Re: Should I switch to an automatic [Re: MadMez] #1504887
09/20/13 07:52 PM
09/20/13 07:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
A stock 727 trans with a manual valve body would work forever in a 12 second car ,that would not be no where near $1200. Put a 9.5 PTC convertor in it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Should I switch to an automatic [Re: RUNCHARGER] #1504888
09/20/13 07:53 PM
09/20/13 07:53 PM
MI
68shifter Offline
68shifter  Offline
MI
Four speed all the way! Breaks my heart revoking man-cards, but sometimes it has to be done.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Should I switch to an automatic [Re: 68shifter] #1504889
09/20/13 08:58 PM
09/20/13 08:58 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Torque converters make great umbrella stands.
There is NO way I'd go back to an auto after racing a 4 speed, I'd probably give up the sport.
Re: Should I switch to an automatic [Re: toddd] #1504890
09/20/13 09:48 PM
09/20/13 09:48 PM
gregsdart Offline
gregsdart  Offline
If you plan on keeping the four speed, check to see if there are any clutches available that would work for your car that will slip a certain amount off the line. Just a thought, I figure if there is, it ought to add some consistency (given the clutch isn't heat sensitive) and save a lot on parts. A rev limiter tied into the linelock would help also.
Re: Should I switch to an automatic [Re: gregsdart] #1504891
09/20/13 10:57 PM
09/20/13 10:57 PM
ohio
all spooled up Offline
ohio
NO NO NO NO
Re: Should I switch to an automatic [Re: Mr.Yuck] #1504892
09/21/13 12:00 AM
09/21/13 12:00 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
All this plus a flex plate, a drive shaft and a trans/flywheel shield.
Brian
Re: Should I switch to an automatic [Re: toddd] #1504893
09/21/13 12:23 AM
09/21/13 12:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
For all you hot shot 4 speed guys.... you think a
conv makes a great stand.. a conv also DOUBLES your
engine torque.... they have a 2X multiplier at the
line.... does your clutch.. or trans do that
