Should I switch to an automatic
#1504874
09/20/13 12:16 PM
09/20/13 12:16 PM
Posts: 260 Slinger WI
MadMez
Slinger WI
Hi everybody! I am considering putting an automatic where the 4 speed lives in my 64 Dodge. The reasoning behind this is hopefully lower maintenance and less parts breakage when bracket racing at GLD. Talk me into, or out of it. If into what sort of stuff does a 727 need to do this keeping in mind I know nothing about automatics. The car is old school with a 383, ported 906s Torker intake, 750 dp, .557” 296 duration solid DC cam and 4.56s in a 9”. It has run as quick as 12.82 and as fast as 109.5 mph. Thanks very much for any and all opinions and information. Tim
Re: Should I switch to an automatic
[Re: LAR_414]
#1504881
09/20/13 01:39 PM
09/20/13 01:39 PM
MadMez
Slinger WI
Your wardrobe will have to change too. Think of the expense for your high heels and skirts alone!
I'll have you know I would look fabulous in a skirt. My legs are strong and well formed. But thats only because they are responsible for dragging the rest of my fat @ss around.
[Re: MadMez]
#1504883
09/20/13 06:06 PM
09/20/13 06:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If your good with the shifter then keep the 4 speed since that is a more efficient way to go... but if you tend to miss the 2-3 shift(and I'm not talking granny shifting)... go with the auto
[Re: MadMez]
#1504887
09/20/13 07:52 PM
09/20/13 07:52 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
A stock 727 trans with a manual valve body would work forever in a 12 second car ,that would not be no where near $1200. Put a 9.5 PTC convertor in it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: toddd]
#1504890
09/20/13 09:48 PM
09/20/13 09:48 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you plan on keeping the four speed, check to see if there are any clutches available that would work for your car that will slip a certain amount off the line. Just a thought, I figure if there is, it ought to add some consistency (given the clutch isn't heat sensitive) and save a lot on parts. A rev limiter tied into the linelock would help also.
[Re: Mr.Yuck]
#1504892
09/21/13 12:00 AM
09/21/13 12:00 AM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
What makes you think an auto is cheaper? A GOOD race 727 is going to run you $1200 or more a converter another $500+ Then you'll need a good shifter $200+, trans lines, trans cooler $150 or so... it adds up. What are you breaking and why? at those speeds a 4 speed should be fine.
All this plus a flex plate, a drive shaft and a trans/flywheel shield. Brian
[Re: toddd]
#1504893
09/21/13 12:23 AM
09/21/13 12:23 AM
MR_P_BODY
Torque converters make great umbrella stands.
There is NO way I'd go back to an auto after racing a 4 speed, I'd probably give up the sport.
For all you hot shot 4 speed guys.... you think a conv makes a great stand.. a conv also DOUBLES your engine torque.... they have a 2X multiplier at the line.... does your clutch.. or trans do that
