small block oil filter adapter,threaded nipple torque? #1504313
09/19/13 11:47 AM
09/19/13 11:47 AM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
on my small block aluminum 90 degree oil filter adapter,there is a threaded nipple(the oil filter screws onto it),this nipple screws into the aluminum adapter. it has a square opening in the center, allen wrench? 3/8s extension? what goes into that to tighten it down? is there a gasket between it and the aluminum adapter? how tight? anything needed to go on steel nipple thread going into aluminum?
Re: small block oil filter adapter,threaded nipple torque? [Re: Joesixpack] #1504314
09/19/13 11:58 AM
09/19/13 11:58 AM
loctite on brake kleened threads. grind down a cheap HF extension. no gasket
Re: small block oil filter adapter,threaded nipple torque? [Re: RapidRobert] #1504315
09/19/13 02:30 PM
09/19/13 02:30 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
thanks, just was in process of doing my "break in" oil change and pulled off filter....and felt the nipple was loose....loctited and installed now!
Re: small block oil filter adapter,threaded nipple torque? [Re: Joesixpack] #1504316
09/19/13 03:05 PM
09/19/13 03:05 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I've generally found Robert's advice to be sound and based on actual experience. I do know of a couple of relatively simple and no cost modifications that you may want to consider at your next oil change. First just having to use the 90* adapter adds some more restrictions to the lube system. If you remove the adapter you will see some pretty tight turns that some porting can help with. Next there are some nipples that don't have the internal square drive hole, but are round inside and nearly 1/2 in. in diameter. They use a hex on the outer flange. If you can't find one it is a relatively simple matter to drill out the square drive [ do it in stages ] to 1/2 in. Then simply grind a hex on the flange so you can use a socket. 13/16 works pretty well. There are plenty of internal drive nipples around since that's what holds the filter plate on small blocks without an adapter. That way if you screw one up replacing it isn't a problem. Re install as Robert said ie. clean threads and blue locktite. Just in case you're interested the large bolt that holds the adapter to the block goes in at 50 ft.lbs. or at least good and tight. I use blue locktite on it as well. Obviously if you can avoid using the adapter that would be best, but I realize some exhaust systems require it.
Re: small block oil filter adapter,threaded nipple torque? [Re: 5spdcuda] #1504317
09/19/13 03:22 PM
09/19/13 03:22 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
.....Next there are some nipples that don't have the internal square drive hole, but are round inside and nearly 1/2 in. in diameter. They use a hex on the outer flange. If you can't find one it is a relatively simple matter to drill out the square drive [ do it in stages ] to 1/2 in. Then simply grind a hex on the flange so you can use a socket. 13/16 works pretty well.....
If you go this way, save yourself some grief. Buy a new socket and grind the entrance ramps off the socket's opening. The flange on the nipple is very thin and most sockets won't firmly grip the nipple which results in rounding off the hex on the nipple. With the socket modification you get full socket engagement and prevent this problem.
Re: small block oil filter adapter,threaded nipple torque? [Re: 6PakBee] #1504318
09/19/13 05:58 PM
09/19/13 05:58 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
about grinding the entrance ramps off, it does make for a better fit on such a thin flange. I usually find an older socket I don't mind grinding on.
Re: small block oil filter adapter,threaded nipple torque? [Re: 5spdcuda] #1504319
09/19/13 07:05 PM
09/19/13 07:05 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
kinda sorta have to use the 90 degree adapter with these headers...
Re: small block oil filter adapter,threaded nipple torque? [Re: Joesixpack] #1504320
09/19/13 09:16 PM
09/19/13 09:16 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Header wrap? Have you had any problem with excessive corrosion underneath the wrap?
Re: small block oil filter adapter,threaded nipple torque? [Re: 6PakBee] #1504321
09/20/13 12:18 AM
09/20/13 12:18 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
I actually bought them that way right off Ebay....new, wrapped,Hooker Super Comps...been 15 minutes run time on them so far...so good. guess they were popular before fancy ceramic metalic coating...
Re: small block oil filter adapter,threaded nipple torque? [Re: Joesixpack] #1504322
09/20/13 09:57 AM
09/20/13 09:57 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Interesting. The only reason I ask is that I had a buddy with a turbocharged BB Chevy that wrapped the tubing from the manifolds to the turbo with some kind of insulation wrap. After about one year as a daily driver the entire tube corroded to the point of failure.
Re: small block oil filter adapter,threaded nipple torque? [Re: 6PakBee] #1504323
09/21/13 10:21 PM
09/21/13 10:21 PM
William I have an extra one that is round on the inside with the hex on the outside. Holler at me if you need it & I'll send it out
Re: small block oil filter adapter,threaded nipple torque? [Re: RapidRobert] #1504324
09/22/13 02:48 PM
09/22/13 02:48 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
i am good thanks, loctited it in and tightened it with 3/8s extension on ratchet. filter on,just have to adjust the rockers,add oil,and the engine is done, now as far as the trans....that is a nother story...
Re: small block oil filter adapter,threaded nipple torque? [Re: Joesixpack] #1504325
09/22/13 07:00 PM
09/22/13 07:00 PM
What's going on there?
Re: small block oil filter adapter,threaded nipple torque? [Re: RapidRobert] #1504326
09/24/13 12:45 AM
09/24/13 12:45 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
broke motor in....1500 rpm for 12-14 minutes, idled down, foot on brake, trans shifted to "R", worked fine, foot on brake, shifted to "N",ok, then 1st, nothing, 2nd,nothing,then 3rd, nothing, no foward gears engaged. fluid level is ok, pulled pan, valve body, performed ATSG air checks of servos&bands, all applied, all worked with air pressure. possible defective turbo action RMVB, dont know, called them today, the tech guy,called me back, i gave him serial#,he said ah 2000 build date, i told him i bought it new but did not build trans till 7 years later, did not put fluid in till weeks ago.he did not have an answer why i would have reverse but not foward gears, send to box up and send back for inspection/repair etc, ok, i have second valve body i bought in 92, gave him that serial #, came out of a working trans, its going in my car am tuesday. hopefully it will work and vb#1 was a defect...if not will pull trans #1 out and tear it apart looking for problem, have trans #2 i bought sat ,318 a-body core,just pulled, will go thru it with mancini hp rebuild kit and install. need to hit road before winter and drive car.
