Re: small block oil filter adapter,threaded nipple torque?
[Re: Joesixpack]
#1504314
09/19/13 11:58 AM
09/19/13 11:58 AM
RapidRobert
loctite on brake kleened threads. grind down a cheap HF extension. no gasket
[Re: Joesixpack]
#1504320
09/19/13 09:16 PM
09/19/13 09:16 PM
Posts: 10,702 North Dakota
6PakBee
North Dakota
Header wrap? Have you had any problem with excessive corrosion underneath the wrap?
[Re: 6PakBee]
#1504323
09/21/13 10:21 PM
09/21/13 10:21 PM
RapidRobert
William I have an extra one that is round on the inside with the hex on the outside. Holler at me if you need it & I'll send it out
[Re: RapidRobert]
#1504326
09/24/13 12:45 AM
09/24/13 12:45 AM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
broke motor in....1500 rpm for 12-14 minutes, idled down, foot on brake, trans shifted to "R", worked fine, foot on brake, shifted to "N",ok, then 1st, nothing, 2nd,nothing,then 3rd, nothing, no foward gears engaged. fluid level is ok, pulled pan, valve body, performed ATSG air checks of servos&bands, all applied, all worked with air pressure. possible defective turbo action RMVB, dont know, called them today, the tech guy,called me back, i gave him serial#,he said ah 2000 build date, i told him i bought it new but did not build trans till 7 years later, did not put fluid in till weeks ago.he did not have an answer why i would have reverse but not foward gears, send to box up and send back for inspection/repair etc, ok, i have second valve body i bought in 92, gave him that serial #, came out of a working trans, its going in my car am tuesday. hopefully it will work and vb#1 was a defect...if not will pull trans #1 out and tear it apart looking for problem, have trans #2 i bought sat ,318 a-body core,just pulled, will go thru it with mancini hp rebuild kit and install. need to hit road before winter and drive car.
