Page 1 of 3 1 2 3
think this may be a problem? #1503486
09/17/13 10:58 PM
09/17/13 10:58 PM
California
mickm Offline OP
mickm  Offline OP
California
so i've been chasing an issue since not long after the engine went in, where it is breaking up, more missing really, at anywhere about 4500-5000, and doesn't have the power it should below that.
had issues with the msd box for a while, and while ignition still isn't ruled out, i decided to check my fuel pressure.
i bought a carter pump from mancini that was supposed to be calibrated for the carter/edelbrock carbs, so about 5.5 - 6 psi.
put a gauge inline today, and it almost immediately jumped to 10 psi, which is pegged on the gauge! and that was barely above idle!
i'll call them tomorrow and see if i have the wrong pump, but i'll have to take of this before i go on.
sigh... well, hopefully it will be this easy!
Re: think this may be a problem? [Re: mickm] #1503487
09/17/13 11:07 PM
09/17/13 11:07 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
can't say if that's your problem but if the gauge is accurate 10# would certainly be suspect of causing problems. even if that isn't the issue it should be corrected.
does the engine run properly above that speed?
Re: think this may be a problem? [Re: jamesc] #1503488
09/17/13 11:16 PM
09/17/13 11:16 PM
California
mickm Offline OP
mickm  Offline OP
California
actually tried two different gauges.
engine runs fine, but is missing when i lay into it. sometimes it's barely noticeable, and sometimes it if very obvious, usually above 5 k.
did a burn out in front of the house the other day, and the neighbor, a drag racer, said it sounded like it was missing.
Re: think this may be a problem? [Re: mickm] #1503489
09/17/13 11:25 PM
09/17/13 11:25 PM
California
mickm Offline OP
mickm  Offline OP
California
just looked on mancini's site. the number on my invoice matches the 5.5 -6 psi pump. and listed right next to it is the strip pump that does 6.9 to 9.5 psi.
hmmmm....
Re: think this may be a problem? [Re: mickm] #1503490
09/18/13 12:42 AM
09/18/13 12:42 AM
Verify your fuel pressure gauge, if it has to much pressure it shouldn't idle worth a hoot, it should load up and die All the carbs(more than one ) that I had to much pressure on did
Re: think this may be a problem? [Re: Cab_Burge] #1503491
09/18/13 10:06 AM
09/18/13 10:06 AM
Guitar Jones Offline
I've had a problem like that. I had the coil mounted on the fender apron, I added a ground from the bracket to the engine and the problem went away.
Re: think this may be a problem? [Re: Cab_Burge] #1503492
09/18/13 11:59 AM
09/18/13 11:59 AM
California
mickm Offline OP
mickm  Offline OP
California
that did seem strange, but we used two different gauges, exactly the same reading.
i figured the result of this would be much worse as well, and can't really explain it.
i just made a new line to one of the carbs from the tee, which consists of a rubber hose with another tee in it, and that tee goes to the gauge, which i have taped to the windshield. nothing wrong there?
Re: think this may be a problem? [Re: Guitar Jones] #1503493
09/18/13 11:59 AM
09/18/13 11:59 AM
California
mickm Offline OP
mickm  Offline OP
California
coil is mounted on the intake manifold. hopefully there is no issue there.
Re: think this may be a problem? [Re: mickm] #1503494
09/18/13 12:07 PM
09/18/13 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pressure is a by product of flow versus restriction
so instead of getting a lower flowing pump just put
one of the Holley regulators in the line to drop the
pressure to 6-ish... those carbs do use less pressure
than a Holley needle and seat
Re: think this may be a problem? [Re: mickm] #1503495
09/18/13 12:28 PM
09/18/13 12:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you`re stuck on the mechanical pump then just install a regulator.............
Re: think this may be a problem? [Re: Thumperdart] #1503496
09/18/13 12:35 PM
09/18/13 12:35 PM
California
mickm Offline OP
mickm  Offline OP
California
that is what i may end up having to do. i have to check the number on the pump to see if it is the right one, and go from there. i talked with mancini and either way i may return and exchange the pump, if it's the race one i don't want it, and if not, it may just be unit that is way off.
i have a stock appearing setup, and was hoping to avoid needing a regulator, which is the reason i paid for this particular pump.
i'm going to temporarily install a regulator and see how it behaves and go from there.
Re: think this may be a problem? [Re: mickm] #1503497
09/18/13 12:47 PM
09/18/13 12:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Like Mike said, could be a restriction creating the added pressure. I personally wouldn`t ever run a mechanical pump for many reasons but I understand yours.
Re: think this may be a problem? [Re: mickm] #1503498
09/18/13 02:41 PM
09/18/13 02:41 PM
I can't remember if we have discussed the needles and seat sizes, have we? If so what size are in your carbs. now? If ther smaller than .090 you may want to change thme to .110 or larger BTW, I have one or two sets of the new Carter .110 left from racing my stocker
Re: think this may be a problem? [Re: Cab_Burge] #1503499
09/18/13 09:31 PM
09/18/13 09:31 PM
California
mickm Offline OP
mickm  Offline OP
California
i have thought about that. there is probably no reason not to on an engine this size.
i'm going to get the regulator in there (hopefully tonight) and take things from there. one step at a time.
but i do need two sets, (nudge nudge, wink wink, say no more, saaaay no more)!
Re: think this may be a problem? [Re: mickm] #1503500
09/18/13 11:30 PM
09/18/13 11:30 PM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
My car was busting up bad under a load, turned out to be a broke rocker arm. It was cracked and still riding on the shaft, the car would actually idle fine, but under a load, it was bad.....Just something to check if you have not already
Re: think this may be a problem? [Re: mickm] #1503501
09/18/13 11:57 PM
09/18/13 11:57 PM
Another thing to check, if you haven't already, on both the Carter and Eddy carbs. is the float drop and float level I like to have both at the longest travel,lowest float drop and the highest, without dripping or flooding, float level on those two brand and type carbs.
Re: think this may be a problem? [Re: Cab_Burge] #1503502
09/19/13 01:58 AM
09/19/13 01:58 AM
California
mickm Offline OP
mickm  Offline OP
California
well, got the regulator in.
set it at 6 psi, and took it out for a drive. under full throttle it steadily dropped off until it leveled at about 2psi. that was about 5500, and by then it was breaking up. not falling off, but missing and breaking up, the problem i'm going after.
A/F mixture stayed the same, in the low to mid 12's, even when it was at 2psi.
now at first i thought that was a big deal, but since it actually had pressure, that means there was something that was resisting it, namely closed needles and seats. also, if it truly was unable to keep up with the demand, then it would have gone lean once the pump could no longer keep up can supply the engine with the gas it needed.
make sense? am i off base??
we are going to tackle the ignition next. we're going to put a points distributor back in and eliminate the entire ignition system and go from there.
someone mentioned a rocker arm. i just adjusted the valves, so i know that isn't an issue.
Re: think this may be a problem? [Re: Cab_Burge] #1503503
09/19/13 02:01 AM
09/19/13 02:01 AM
California
mickm Offline OP
mickm  Offline OP
California
so how far beyond the stock settings do you go? until it does start dripping or flooding?
Re: think this may be a problem? [Re: mickm] #1503504
09/19/13 12:44 PM
09/19/13 12:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What fuel line sizes r u running.............? Stock tank?
Re: think this may be a problem? [Re: Thumperdart] #1503505
09/19/13 01:27 PM
09/19/13 01:27 PM
California
mickm Offline OP
mickm  Offline OP
California
stock tank, new fuel lines, 3/8" to the pump, 5/16" to the carbs.
now, before anyone jumps all over that as not enough, i'm going by what tim banning does. he uses this setup on all his 572, 750+ HP street bemis, unless the customer asks for something different. it certainly is possible that in my case it isn't enough, and if so i'll figure that out and change it, but there is a proven track record of this combo working, so until i prove it isn't, i'll stick with it.
it looks to me like for whatever reason, the carbs were holding out well against that 10psi most of the time, as it really didn't run differently with the regulator in place.
Page 1 of 3 1 2 3
