Need carb # for a 78 b200 van w/ a 318 #1503111
09/17/13 01:27 PM
09/17/13 01:27 PM
Appleton WI 54911
Lukester Offline OP
Lukester  Offline OP
Appleton WI 54911
Bought a 78 dodge b200 with what I think is the wrong carb. A Holley 2 bbl looks to be the right fit. The one on it does not even have threads for the air cleaner stud. Van has cruise. The vin is....B21BF8X122503
I would like to buy a correct reman but don't have a number. Any help would be appreciated.
Re: Need carb # for a 78 b200 van w/ a 318 [Re: Lukester] #1503112
09/17/13 02:17 PM
09/17/13 02:17 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Have you tried any parts stores? They tend to have the correct carb listed.
Re: Need carb # for a 78 b200 van w/ a 318 [Re: 76dodgeboy] #1503113
09/18/13 08:29 AM
09/18/13 08:29 AM
Appleton WI 54911
Lukester Offline OP
Lukester  Offline OP
Appleton WI 54911
My parts store can't figure it out. There are AT LEAST 12 different options...... The carb that was put on the van is obviously not right.... The one I need has a threaded carb stud hole, a vacuum pod for the choke, and a plug for some wire.
Re: Need carb # for a 78 b200 van w/ a 318 [Re: Lukester] #1503114
09/18/13 11:42 AM
09/18/13 11:42 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I really doubt there's 12 different carb choices for a 318
Re: Need carb # for a 78 b200 van w/ a 318 [Re: 76dodgeboy] #1503115
09/18/13 01:26 PM
09/18/13 01:26 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
California vs federal/canada emissions
standard vs automatic
high altitude vs low altitude ect... Without looking in the parts catalog I can easily see several different part numbers.
The real difference between all of them maybe nothing more than a jet/needle size and some adjustment settings but back in the day all of those little things made each carb p/n unique to its application.
78 2bbl 318 would have most likely had a carter BBD.
Re: Need carb # for a 78 b200 van w/ a 318 [Re: 135sohc] #1503116
09/18/13 02:09 PM
09/18/13 02:09 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Rockauto shows only the bbd only 4 carbs shown at Advance Auto. Still don't see 12 variations. You have to tune them for your location as in altitude
Re: Need carb # for a 78 b200 van w/ a 318 [Re: Lukester] #1503117
09/18/13 02:30 PM
09/18/13 02:30 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Online shocked
dynotune440  Online Shocked
make sure on the engine size, by the VIN, the van is a 360, or at least what it left the factory with.
If it is a 360, then it would be a holley....if it is a 318, then it would be a carter BBD or holey replacement carb....
good luck...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Need carb # for a 78 b200 van w/ a 318 [Re: dynotune440] #1503118
09/18/13 02:34 PM
09/18/13 02:34 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Any pics
Re: Need carb # for a 78 b200 van w/ a 318 [Re: 76dodgeboy] #1503119
09/20/13 08:11 AM
09/20/13 08:11 AM
Appleton WI 54911
Lukester Offline OP
Lukester  Offline OP
Appleton WI 54911
So... I called an older Dodge dealer and had them run the vin.... They said it was a 360 built in Missouri with federal emissions, and a 6-10,000 GVW and it came with a holley 2BBl. he gave me factory 2 carb #s to choose from... R8925A and R9816A. I crawled under the van and had a look at the block #s and it still is the original 360. so I went to my local bumper to bumper and they said I now had two choices, and only one is available... lol .... United reman # 6-6264.... It will be in later today, and I can take a look.... It should be way closer than what's on there...
Re: Need carb # for a 78 b200 van w/ a 318 [Re: 76dodgeboy] #1503120
09/20/13 08:14 AM
09/20/13 08:14 AM
Appleton WI 54911
Lukester Offline OP
Lukester  Offline OP
Appleton WI 54911
Only if you tell them the correct motor thats in the vehicle...:)
Re: Need carb # for a 78 b200 van w/ a 318 [Re: Lukester] #1503121
09/20/13 11:23 AM
09/20/13 11:23 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You probably should have checked to make sure what motor it was from the start
Re: Need carb # for a 78 b200 van w/ a 318 [Re: Lukester] #1503122
09/20/13 01:03 PM
09/20/13 01:03 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
That is a very sharp looking stubby van ... very similiar looking one for sale near me, but spendy ...
It takes gasoline to interest me.
Re: Need carb # for a 78 b200 van w/ a 318 [Re: VL21] #1503123
09/20/13 02:22 PM
09/20/13 02:22 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
