Header tether rule update.. #1502988
09/17/13 03:24 AM
09/17/13 03:24 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
For thos who have not heard the NHRA has ammended it's tehter rule for 2014. Here is the latest version of the rule. Basically if you dont want to run one of the NHRA approved tethers from the two approved vendors you can simply have a 1/2" stitch weld to each primary tube. I am sure there will be more changes as it gets closer to next year.
Here is the link
http://www.nhraracer.com/content/general.asp?articleid=56756&zoneid=132
Re: Header tether rule update.. [Re: Al_Alguire] #1502989
09/17/13 07:23 AM
09/17/13 07:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have no problem with saftey. This fix is not rocket science. But I quote "The NHRA Technical Department will not accept Tethering System requests from individual racers, as this will inundate our resources and create an impossible situation to regulate in the field." For a group that only checks seat belt dates at tech, no wonder a statement like this is made. I personally will not weld my headers or pay $200 for an "approved system" .Whats wrong with a cable from the trans to to a bracket under the O2 bung? $5 worth of material.
Doug
Re: Header tether rule update.. [Re: Al_Alguire] #1502990
09/17/13 09:25 AM
09/17/13 09:25 AM
Out West
408strokerdart Offline
Out West
This isn't really much help for cars that have headers that need to come out tube by tube. I wonder if they would accept it if one tube was welded to the collector and the rest were slip fit?
Re: Header tether rule update.. [Re: 408strokerdart] #1502991
09/17/13 12:33 PM
09/17/13 12:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i bet unless you are at a national event no one ever looks.
Re: Header tether rule update.. [Re: Quicktree] #1502992
09/17/13 12:42 PM
09/17/13 12:42 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
A header collector came out from a nitrous car at the yellobullet nationals. Luckily he didn't drive over it, just fell on the ground at 60'. I just think they should require bolts inplace of springs.
Re: Header tether rule update.. [Re: Defbob] #1502993
09/17/13 05:28 PM
09/17/13 05:28 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I have welded on tabs & collectors are bolted together, wonder if i'll still need a tether?
Re: Header tether rule update.. [Re: rickraw] #1502994
09/17/13 05:42 PM
09/17/13 05:42 PM
Las Vegas
Las Vegas
Yes tabs and bolts as of 2014 will NOT be legal. You will either need one of the two excessively priced NHRA approved tether systems or as amended a one inch stich weld on ALL the primary tubes. Results of racers NOT doing maintenance on their cars and causing injury to others.
I have tabs, bolts and mufflers and still have to conform to the new rule.
Re: Header tether rule update.. [Re: Al_Alguire] #1502995
09/17/13 05:52 PM
09/17/13 05:52 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Lest see, by the time I get my ride back out. Have no idea when that will be
I'll need
New belts (6 passes)
New helmet (hardly worn, like new)
New jacket (never been washed)
Diaper
Header restraints
What else am I missing?????
Re: Header tether rule update.. [Re: roadhazard] #1502996
09/17/13 06:01 PM
09/17/13 06:01 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
What's the ruling if the car has pipes and mufflers on it?
Photobucket sucks
Re: Header tether rule update.. [Re: roadhazard] #1502997
09/17/13 06:04 PM
09/17/13 06:04 PM
tboomer Offline
tboomer  Offline
I'll need
Diaper
Header restraints
A buttload of cash!!
Re: Header tether rule update.. [Re: tboomer] #1502998
09/17/13 06:19 PM
09/17/13 06:19 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
I was planning the stitch weld deal but then again I have 2 sets of headers for different motor combo's that are nicely coated so probably will eventually bite the bullet and order an approved kit, just hope this does not turn out like the window net deal of a year or two back or the ........ well you get the idea.
Re: Header tether rule update.. [Re: tboomer] #1502999
09/17/13 06:20 PM
09/17/13 06:20 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'll need
Diaper
Header restraints
And a jar of that special petroleum jelly
I'm all for being safe and the safety of everyone else. If they are going to check for tethers on my headers, why can't they just look to make sure my tabs are bolted properly?
Maybe they should have sealed lug nuts
Once they are torqued you can not remove them without the express written permission of the NHRA
Re: Header tether rule update.. [Re: 72chrgrally] #1503000
09/17/13 06:31 PM
09/17/13 06:31 PM
Las Vegas
Las Vegas
The way the rule still currently reads is if you have a slip on collector you have to either stitch weld or purchase the approved tethers. Since I have mufflers that was why I asked and that was the answer I was given last week.
Re: Header tether rule update.. [Re: Al_Alguire] #1503001
09/17/13 06:37 PM
09/17/13 06:37 PM
Chesterfield Twp. Mi.
John Burdine Offline
good lord, 4 tabs nut/bolts should have been fine. a couple of the NHRA's buddys get to make some money now.
Re: Header tether rule update.. [Re: John Burdine] #1503002
09/17/13 06:42 PM
09/17/13 06:42 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Is this just NHRA or did IHRA mandate this too?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Header tether rule update.. [Re: Al_Alguire] #1503003
09/17/13 07:11 PM
09/17/13 07:11 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
yea cause we all know welds on headers never crack
nhra...gotta love em
Re: Header tether rule update.. [Re: jamesc] #1503004
09/17/13 08:05 PM
09/17/13 08:05 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I guess if u have a full exhaust where it would be impossible for the collector to come off u still need a tether. Boy, u would need lots of tethering to hold the whole exhaust system on.
Re: Header tether rule update.. [Re: pittsburghracer] #1503005
09/17/13 08:30 PM
09/17/13 08:30 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
THIS is on my mind also
Re: Header tether rule update.. [Re: roadhazard] #1503006
09/17/13 09:38 PM
09/17/13 09:38 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
can any one say even more kick backs.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Header tether rule update.. [Re: dusturbd340W5] #1503007
09/17/13 09:41 PM
09/17/13 09:41 PM
Kissimmee Fl.
Kissimmee Fl.
I have been depressed for over 2 years that I had to sell my ride BUT the more crap that comes out like this the better I feel about it.
When I do get to go back to racing it will most likely be on a bike very little safety stuff there to worry about.
no belt issue no net no ect ect.
