Page 3 of 5 1 2 3 4 5
Re: Ok so I broke a rod ! [Re: CompWedgeEngines] #1502635
09/17/13 03:19 PM
09/17/13 03:19 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
Give me a minute to type it!!!!!
Ha! super quick respnose!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Ok so I broke a rod ! [Re: CompWedgeEngines] #1502636
09/17/13 03:25 PM
09/17/13 03:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Sorry Jamie but you went red bigtime on that one!!
Re: Ok so I broke a rod ! [Re: dartman366] #1502637
09/17/13 05:58 PM
09/17/13 05:58 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
No I was not red... !!!
Re: Ok so I broke a rod ! [Re: VernMotor] #1502638
09/17/13 06:45 PM
09/17/13 06:45 PM
Renton Washington
Triple Threat Offline
Renton Washington
LB3A
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Ok so I broke a rod ! [Re: Triple Threat] #1502639
09/17/13 07:15 PM
09/17/13 07:15 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
hate to see broken parts like that. not being a smart a$$ but what rods will you be using in the next build?
Re: Ok so I broke a rod ! [Re: jamesc] #1502640
09/17/13 09:10 PM
09/17/13 09:10 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
good question James.. maybe K1 or Molnar ? I not sure it was completely the rod fraud yet. I just got the head off. will post some more pics here in a few. Face it there are 1000s of motor's out there with eagle rods in them.with more hp Than I got.
Re: Ok so I broke a rod ! [Re: VernMotor] #1502641
09/17/13 09:22 PM
09/17/13 09:22 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Very sorry to hear that,Vern! NO rod is bulletproof! And as far as Big Block's having oiling problems....BS! Hope you build an even BETTER motor next time around!
Re: Ok so I broke a rod ! [Re: Labratt] #1502642
09/17/13 09:30 PM
09/17/13 09:30 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Re: Ok so I broke a rod ! [Re: VernMotor] #1502643
09/17/13 10:01 PM
09/17/13 10:01 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
What...you dont trust me????....
RIP Monte Smith
Re: Ok so I broke a rod ! [Re: CompWedgeEngines] #1502644
09/17/13 10:05 PM
09/17/13 10:05 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I Just thought I throw it out there and see:) you know I trust ya !
Re: Ok so I broke a rod ! [Re: VernMotor] #1502645
09/17/13 10:06 PM
09/17/13 10:06 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
You look at them new pics I put in the first post ?
Re: Ok so I broke a rod ! [Re: VernMotor] #1502646
09/17/13 10:07 PM
09/17/13 10:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
From your new pics, it looks like there was a little heat at the wrist pin, on just the one pic, the other no heat, just a simple break. And then smash baam and all the rest. Is there any evidence of heat there or is that just the pics shadows.
Sorry to hear of the mayham, Jamie.
Re: Ok so I broke a rod ! [Re: VernMotor] #1502647
09/17/13 10:08 PM
09/17/13 10:08 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
im no expert....
BUT i would speculate that the cyl wall cracked....
filled that hole with some water and...then your rod broke
....BAD A$$ STREET CAR.....
Re: Ok so I broke a rod ! [Re: Sport440] #1502648
09/17/13 10:08 PM
09/17/13 10:08 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
It is just the pic. I can not see any signs of heat at all.
Re: Ok so I broke a rod ! [Re: n20mstr] #1502649
09/17/13 10:10 PM
09/17/13 10:10 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
im no expert....
You might be on to something there. The wall looks a little thin where it opened up.
Sorry for your bad luck. It definitely looks expensive.
Re: Ok so I broke a rod ! [Re: n20mstr] #1502650
09/17/13 10:11 PM
09/17/13 10:11 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
im no expert....
At first I considered that too, but a broken rod at the wrist pin, will beat that area up pretty bad if its still attached to the crank, and it was.
Re: Ok so I broke a rod ! [Re: CompWedgeEngines] #1502651
09/17/13 10:12 PM
09/17/13 10:12 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
So what broke first, the piston, the rod or might it have seized a pin?
Kevin
Re: Ok so I broke a rod ! [Re: Twostick] #1502652
09/17/13 10:23 PM
09/17/13 10:23 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Kevin
With Jamies last post about no heat, and looking at the piston again, with it being beat out pretty good at the angle the rod would beat on it, is simply the rod broke first for sure IMO at the wrist pin, all else followed.
The good news, IMO is it got shut down fast enough to save the heads. Ive seen mayham spread to a bunch of other cylinders causing alot more damage to the rest of the chambers.
Re: Ok so I broke a rod ! head off more pics [Re: VernMotor] #1502653
09/17/13 10:26 PM
09/17/13 10:26 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I have never seen an oil ring wrapped around valves before.
Hell, if you're gonna break, might as well make it memorable.
Re: Ok so I broke a rod ! head off more pics [Re: dustergirl340] #1502654
09/17/13 10:39 PM
09/17/13 10:39 PM
Syracuse,NY
Syracuse,NY
You know Jamie Dustergirl....always showboating for the glamour shots !
I didnt look at them yet Jamie no.,
RIP Monte Smith
