how tight are valve cover bolts supposed to be? #1501909
09/15/13 05:30 PM
09/15/13 05:30 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I saw a little oil leaking from my lower center bolt on my passenger side valve cover. When I went to tighten it up a little, I found all the blots could be loosened by hand. Are they supposed to be this loose or should I snug them down?
I know there are no stupid questions....just stupid people.
That's me!! Thanks for any help.
Re: how tight are valve cover bolts supposed to be? [Re: fireeng] #1501910
09/15/13 06:05 PM
09/15/13 06:05 PM
Kirkland, Washington
Pacnorthcuda Offline
72 inch pounds is the spec I've seen. I usually go about 50-60 inch pounds. I also recheck every couple days with new gaskets cause they do compress.
Re: how tight are valve cover bolts supposed to be? [Re: fireeng] #1501911
09/15/13 06:05 PM
09/15/13 06:05 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I know there is a torque spec for them, can't remember it off the top of my head.
I tend to get them all snug, then give them about an eighth to a quarter turn, depending on the material.
You can always give them a bit more, but once they are overtightened, they gotta be replaced!
Re: how tight are valve cover bolts supposed to be? [Re: RodStRace] #1501912
09/15/13 06:11 PM
09/15/13 06:11 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
How old are the gaskets? They may shrink some as the get heated up. I never bothered to torque them, I use a 3/8" ratchet and watch the gasket.....guess Ive done a few...
I always use right stuff gasket maker (SPARINGLY) on all my gaskets, and let it set up before using it. usually never have a leak.....
You can always tighten it till it strips and back it off a 1/4 turn.
Re: how tight are valve cover bolts supposed to be? [Re: fireeng] #1501913
09/15/13 07:05 PM
09/15/13 07:05 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I just put Moroso valve covers and Moroso rubber gaskets on my 383. I snug 'em down, rotating around a little bit at a time. I hold the ratchet kindda like a screw driver, not by the handle per se so as not to get too much leverage. Snug 'em till I like it. Have never had a problem with leaks. It's all in the feel.
I've done it this way since I was a kid (15 years old in '62) on all kinds of engines and gasket material.
Just sayin'
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: how tight are valve cover bolts supposed to be? [Re: Junky] #1501914
09/15/13 08:25 PM
09/15/13 08:25 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yes...
Re: how tight are valve cover bolts supposed to be? [Re: RSNOMO] #1501915
09/15/13 10:00 PM
09/15/13 10:00 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Snug them until they are tight enough not to leak. With valve cover, oil pan, timing cover (B/RB) and transmission pan gaskets I've bought myself more grief tightening to a specification than just snugging them down and then re-tightening them if required.
Re: how tight are valve cover bolts supposed to be? [Re: fireeng] #1501916
09/15/13 10:03 PM
09/15/13 10:03 PM
A little too loose is better than too tight. Several rounds (at least) of crisscross tightening. "The right stuff" gasket cement on the gasket will not leak
Re: how tight are valve cover bolts supposed to be? [Re: RapidRobert] #1501917
09/15/13 10:17 PM
09/15/13 10:17 PM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
40 inch lbs as per the 65 fsm. I've never measured, just used ratchet like screwdriver as stated earlier, or use a nut driver.
Re: how tight are valve cover bolts supposed to be? [Re: Carsavior] #1501918
09/16/13 03:40 PM
09/16/13 03:40 PM
dogdays Offline
dogdays  Offline
Not very.
R.
Re: how tight are valve cover bolts supposed to be? [Re: dogdays] #1501919
09/16/13 11:31 PM
09/16/13 11:31 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Thanks guys, snugged them just a bit but not too much....I hope
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: how tight are valve cover bolts supposed to be? [Re: fireeng] #1501920
09/16/13 11:38 PM
09/16/13 11:38 PM
Ding ding ding I do believe we have a winna
