how tight are valve cover bolts supposed to be?
#1501909
09/15/13 05:30 PM
09/15/13 05:30 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
I saw a little oil leaking from my lower center bolt on my passenger side valve cover. When I went to tighten it up a little, I found all the blots could be loosened by hand. Are they supposed to be this loose or should I snug them down?
I know there are no stupid questions....just stupid people. That's me!! Thanks for any help.
Re: how tight are valve cover bolts supposed to be?
[Re: fireeng]
#1501911
09/15/13 06:05 PM
09/15/13 06:05 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I know there is a torque spec for them, can't remember it off the top of my head. I tend to get them all snug, then give them about an eighth to a quarter turn, depending on the material. You can always give them a bit more, but once they are overtightened, they gotta be replaced!
[Re: RodStRace]
#1501912
09/15/13 06:11 PM
09/15/13 06:11 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
How old are the gaskets? They may shrink some as the get heated up. I never bothered to torque them, I use a 3/8" ratchet and watch the gasket.....guess Ive done a few... I always use right stuff gasket maker (SPARINGLY) on all my gaskets, and let it set up before using it. usually never have a leak..... You can always tighten it till it strips and back it off a 1/4 turn.
[Re: fireeng]
#1501913
09/15/13 07:05 PM
09/15/13 07:05 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I just put Moroso valve covers and Moroso rubber gaskets on my 383. I snug 'em down, rotating around a little bit at a time. I hold the ratchet kindda like a screw driver, not by the handle per se so as not to get too much leverage. Snug 'em till I like it. Have never had a problem with leaks. It's all in the feel. I've done it this way since I was a kid (15 years old in '62) on all kinds of engines and gasket material. Just sayin'
[Re: Junky]
#1501914
09/15/13 08:25 PM
09/15/13 08:25 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Yes...
[Re: RSNOMO]
#1501915
09/15/13 10:00 PM
09/15/13 10:00 PM
Posts: 10,730 North Dakota
6PakBee
North Dakota
Snug them until they are tight enough not to leak. With valve cover, oil pan, timing cover (B/RB) and transmission pan gaskets I've bought myself more grief tightening to a specification than just snugging them down and then re-tightening them if required.
[Re: fireeng]
#1501916
09/15/13 10:03 PM
09/15/13 10:03 PM
RapidRobert
A little too loose is better than too tight. Several rounds (at least) of crisscross tightening. "The right stuff" gasket cement on the gasket will not leak
[Re: Carsavior]
#1501918
09/16/13 03:40 PM
09/16/13 03:40 PM
dogdays
[Re: dogdays]
#1501919
09/16/13 11:31 PM
09/16/13 11:31 PM
fireeng
near New Haven, CT
Thanks guys, snugged them just a bit but not too much....I hope
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
