TF-2 Shift Kit Question #1500604
09/12/13 08:56 PM
09/12/13 08:56 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm almost done installing a TF2 shift kit in my 727. The last step has me installing a new spring and spacer on the low-reverse piston.
My question is- Can I take out the low-reverse band adjusting arm with the transmission in the car? It looks like the pin that the arm pivots on is held in by the tailshaft housing... Do I have to take the tailshaft housing off to complete the last step of this shift kit???
Seems like a lot of work to modify the low-reverse band piston.
Re: TF-2 Shift Kit Question [Re: mopowers] #1500605
09/12/13 09:09 PM
09/12/13 09:09 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
You have to pull the pull the tail housing to get that pin out , if YOU think you might have a leak back there do it and replace the o ring on the shaft , put in 2 if the shaft has 2 grooves abd use RTV , otherwise you should be able to loosen the adjuster all the way and get the piston out . It's been some time that I did one of these to a trans that wasn't apart on my bench so I may be wrong, but the TF-2 instructions are centered on modifying a trans that is still installed in the car.
Re: TF-2 Shift Kit Question [Re: JohnRR] #1500606
09/12/13 09:26 PM
09/12/13 09:26 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks! I just went through a TON of old threads about the TF2 kits. It looks like I can loosen the adjuster all the way and pry the band off without pushing the pin out. We'll see... Time to go finish this job. Who'd have though this kit would take all day to install...
Re: TF-2 Shift Kit Question [Re: mopowers] #1500607
09/12/13 09:27 PM
09/12/13 09:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If I remember correctly, loosening the LR band adjuster all the way,
will allow you to sneak up onto the band itself, (think long screwdriver)
And drop the band to linkage spacer out.
That will allow the linkage to swing down out of the way and then allow you to remover the LR piston/servo assy. Hope this makes sense and helps. Reverse the above to put the spacer back in. The spacer looks like a short piece of 1" or so strap steel.
Re: TF-2 Shift Kit Question [Re: TJP] #1500608
09/12/13 09:56 PM
09/12/13 09:56 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
Here's how I got around that part. I simply removed all the bolts from the tail shaft then turned the tail shaft so that the pin wound come out far enought to get that arm out of the way. Got lucky and never had a leak when I put it all back together.
Re: TF-2 Shift Kit Question [Re: High Impact] #1500609
09/12/13 10:29 PM
09/12/13 10:29 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
You don`t need to pull the rear housing. Do what tjp says.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: TF-2 Shift Kit Question [Re: stickman] #1500610
09/13/13 12:35 AM
09/13/13 12:35 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I was able to get it done with a couple screwdrivers and some choice bad words. Got it done though! Thanks guys.
