How to install this external Milodon Oil Pump??? HELP
#1500559
09/12/13 07:39 PM
09/12/13 07:39 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Hi!
I have this new Milodon oil pump but it has no instruction sheets. I bought it as a package deal with some other race parts.
Its old, its been on a shelf for quite a bit but it is new.
I know C and D are the inlets that go to the oil pickup.
What about A and B? I know those are for the oil filter but which one is the send and which the return?
Also what is E for???
Re: How to install this external Milodon Oil Pump??? HELP
[Re: domingo]
#1500560
09/12/13 07:40 PM
09/12/13 07:40 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500562
09/12/13 08:18 PM
09/12/13 08:18 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
A would be out to the filter. B is the inlet back to the main galley. That small extra was added. It is in common with the main galley, so it could be a feed to something external(turbo/ supercharger, oil accumulator, or as some guys would do, plumb it to the oil feed taps on the rear of the block) Or it could be an access to bleed the miserable thing everytime it looses its prime ![](/ubbthreads/images/graemlins/grin.gif)
[Re: domingo]
#1500567
09/13/13 09:18 PM
09/13/13 09:18 PM
Posts: 16,546 On the run…
BloFish
On the run…
That's what I run. You now have the info you need, good luck.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: domingo]
#1500570
09/14/13 10:19 PM
09/14/13 10:19 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500571
09/14/13 10:19 PM
09/14/13 10:19 PM
domingo
EL Master
EL Master
Lima, Peru
3
[Re: domingo]
#1500572
09/14/13 10:21 PM
09/14/13 10:21 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500573
09/14/13 10:22 PM
09/14/13 10:22 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500574
09/14/13 10:23 PM
09/14/13 10:23 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500575
09/14/13 10:24 PM
09/14/13 10:24 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500576
09/14/13 10:25 PM
09/14/13 10:25 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500577
09/14/13 10:26 PM
09/14/13 10:26 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500578
09/14/13 10:27 PM
09/14/13 10:27 PM
domingo
EL Master
EL Master
Lima, Peru
