How to install this external Milodon Oil Pump??? HELP #1500559
09/12/13 07:39 PM
09/12/13 07:39 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I have this new Milodon oil pump but it has no instruction sheets. I bought it as a package deal with some other race parts.
Its old, its been on a shelf for quite a bit but it is new.
I know C and D are the inlets that go to the oil pickup.
What about A and B? I know those are for the oil filter but which one is the send and which the return?
Also what is E for???
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500560
09/12/13 07:40 PM
09/12/13 07:40 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
2nd pic
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500561
09/12/13 08:17 PM
09/12/13 08:17 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Didn't dig into these, but might have what you need...
MIlodon Instruction Manuals
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500562
09/12/13 08:18 PM
09/12/13 08:18 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A would be out to the filter. B is the inlet back to the main galley. That small extra was added. It is in common with the main galley, so it could be a feed to something external(turbo/ supercharger, oil accumulator, or as some guys would do, plumb it to the oil feed taps on the rear of the block)
Or it could be an access to bleed the miserable thing everytime it looses its prime
Re: How to install this external Milodon Oil Pump??? HELP [Re: TRENDZ] #1500563
09/12/13 08:22 PM
09/12/13 08:22 PM
Treed
Re: How to install this external Milodon Oil Pump??? HELP [Re: Cab_Burge] #1500564
09/12/13 10:35 PM
09/12/13 10:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That cover is for a remote oil filter.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500565
09/12/13 10:51 PM
09/12/13 10:51 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Do not torque that pump to factory specs. It will bind the gears and shear the shaft. Use no more than 12 inch pounds of torque when you install the pump. I know that isn't a lot but it works and the pump will not leak. Don't ask how I know this.
Re: How to install this external Milodon Oil Pump??? HELP [Re: Dabee] #1500566
09/13/13 08:27 PM
09/13/13 08:27 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks for the replies!!!
Thanks for the tip on how to torque it too!!!
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500567
09/13/13 09:18 PM
09/13/13 09:18 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
That's what I run. You now have the info you need, good luck.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: How to install this external Milodon Oil Pump??? HELP [Re: BloFish] #1500568
09/14/13 12:09 AM
09/14/13 12:09 AM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
Oil Pump,Plug on bottom for accumulator
Ain't nuthin like a HEMI !
Re: How to install this external Milodon Oil Pump??? HELP [Re: Mulehead] #1500569
09/14/13 10:18 PM
09/14/13 10:18 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hey guys....
I dissambled my pump to check out its condition (its new, but seems it has been bouncing around on a shop, and used for mockups, etc but never actually run) and this is what I found on the inside.
Seems it has been dissassembled and inside a bucket and tossed aroud and the pump rotor is nicked....and also the pump plate cover has a nick.
Would you guys say this makes it unuseable or would it still be good?
pics:
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500570
09/14/13 10:19 PM
09/14/13 10:19 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
2 closeup of the nick
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500571
09/14/13 10:19 PM
09/14/13 10:19 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
3
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500572
09/14/13 10:21 PM
09/14/13 10:21 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500573
09/14/13 10:22 PM
09/14/13 10:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500574
09/14/13 10:23 PM
09/14/13 10:23 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500575
09/14/13 10:24 PM
09/14/13 10:24 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500576
09/14/13 10:25 PM
09/14/13 10:25 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
8
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500577
09/14/13 10:26 PM
09/14/13 10:26 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
9
Re: How to install this external Milodon Oil Pump??? HELP [Re: domingo] #1500578
09/14/13 10:27 PM
09/14/13 10:27 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
10
