Re: Hood / Shaker clearance
[Re: 70GranCoupe]
#1500314
09/12/13 10:56 AM
09/12/13 10:56 AM
Posts: 12,192 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have the tall Indy intake and Dominator under my Shaker.
I got an after market Shaker base and put a drop base in it and shimmed the K down. Then I had to mill 1/2" off the intake. But it fits just fine.
I also ended up dropping the tranny tail down the same amount as the K to keep the front joint out of bind.
Fabbing in a drop base alone may be enough for your combo.
Master, again and still
[Re: Kudakidd]
#1500316
09/12/13 08:38 PM
09/12/13 08:38 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Something wrong?!?!? That Indy intake is TALL.
Which intake do you have that took a 1" spacer and still fit under the Shaker with the Dominator carb? And you didn't lower the Shaker base when you modified it for the larger Dominator throat?
We have got to be talking different combos here.
