Question of 2 Jeeps..Liberty and Wrangler
#1500253
09/11/13 09:22 PM
09/11/13 09:22 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
A friend of mine has a '02 Liberty.. He says he's not getting heat through the vents.The temp gauge warms up and the t-stat appears to open, as the gauge drops a little. the fan operates only sometimes and mostly on high. That leads me to believe a blower motor resistor. But still no heat.. Any suggestions??
Also, a different friend is looking at a '99 Wrangler with a 4 cylinder,5 spd.. He wants to lift it and put 33's or 35's under it.. Is the 4 cylinder a capable engine for offroading with tires that size?
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Question of 2 Jeeps..Liberty and Wrangler
[Re: KatFysh]
#1500254
09/12/13 12:10 AM
09/12/13 12:10 AM
Posts: 905 SD
zrxkawboy
SD
The Libby sounds like a blend air door issue. Feel the heater hoses to see if hot coolant is going through the heater core. Also, replace the blower motor resistor, like you said.
It's Swifty! Swifty, you toad sucker!
[Re: TrueSpirit76]
#1500263
09/14/13 10:18 AM
09/14/13 10:18 AM
KatFysh
Falconer, NY
Yes.. there are 2 problems with the Liberty.. When my friend 1st started telling me the problem, I thought resistor.. Then, later, he came back with the info about about not getting the heat out at all, at times..I thought blend door but wasn't positive. I know back between '91 and '97 at a Linc/Merc dealer, 7x out of 10, the problem was the blend door. Thanks guys. Sorry for any confusion..
