Question of 2 Jeeps..Liberty and Wrangler #1500253
09/11/13 09:22 PM
09/11/13 09:22 PM
Falconer, NY
KatFysh Offline OP
KatFysh  Offline OP
Falconer, NY
A friend of mine has a '02 Liberty.. He says he's not getting heat through the vents.The temp gauge warms up and the t-stat appears to open, as the gauge drops a little. the fan operates only sometimes and mostly on high. That leads me to believe a blower motor resistor. But still no heat.. Any suggestions??
Also, a different friend is looking at a '99 Wrangler with a 4 cylinder,5 spd.. He wants to lift it and put 33's or 35's under it.. Is the 4 cylinder a capable engine for offroading with tires that size?
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: KatFysh] #1500254
09/12/13 12:10 AM
09/12/13 12:10 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
The Libby sounds like a blend air door issue. Feel the heater hoses to see if hot coolant is going through the heater core. Also, replace the blower motor resistor, like you said.
It's Swifty! Swifty, you toad sucker!
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: zrxkawboy] #1500255
09/12/13 12:55 PM
09/12/13 12:55 PM
dogdays Offline
dogdays  Offline
4-cylinder Wrangler on 33s? Don't bother unless you really deepen the gears, just my
R.
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: KatFysh] #1500256
09/12/13 04:32 PM
09/12/13 04:32 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've heard those 4cyls are extremely gutless as it is.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: GoodysGotaCuda] #1500257
09/12/13 05:18 PM
09/12/13 05:18 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
33"-4.56 35"-4.88 Toyota can do it no reason a Jeep can't
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: 76dodgeboy] #1500258
09/12/13 10:43 PM
09/12/13 10:43 PM
Falconer, NY
KatFysh Offline OP
KatFysh  Offline OP
Falconer, NY
thanks guys.. I was thinking blend door also.. a Yoda has 4.10's for gearing from the factory though. Jeeps probably aren't geared that good are they?
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: KatFysh] #1500259
09/12/13 10:55 PM
09/12/13 10:55 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
STOP, I have a replacement blower motor resistor in my hand right now for the wife's 2006 liberty, they are known to fail.
IF the motor won't work on some of the 4 settings its NOT the blend door.
the resistor "card" is a $20 part.
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: KatFysh] #1500260
09/12/13 10:59 PM
09/12/13 10:59 PM
tucson az
frank Offline
frank  Offline
tucson az
Don't know about the Liberty but the 4 cylinder in the Wrangler is gutless. I have a 99/six cylinder/5 speed with 33's and 3.73 gears. Good enough for me but most would go with more gear.
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: Pacnorthcuda] #1500261
09/13/13 12:24 AM
09/13/13 12:24 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
He said the fan only works on high, but still no heat. This leads me to believe there are 2 problems. Maybe I misunderstood.
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: zrxkawboy] #1500262
09/13/13 10:23 AM
09/13/13 10:23 AM
Wisconsin Rapids,WI
TrueSpirit76 Offline
Wisconsin Rapids,WI
Yes to two problems. Our 2005 Liberty Renegade has the defective broken blend door, very common with Grand Cherokee and Liberty. Chrysler cheaped out and put a plastic hinge on them so they all eventually fail. The $2.00 replacement has a metal hinge but is a 600-800 dollar job if you call the dealership, the dash needs to be taken apart.Yes we replaced the resistor on ours also, the Car Quest part and the dealership part are the same-Made In Mexico- so you can choose to buy it from anybody. The hardest part with that was figuring out how to get the little red thing to release...I can't remember how it goes..Google. Hope this helps.
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: TrueSpirit76] #1500263
09/14/13 10:18 AM
09/14/13 10:18 AM
Falconer, NY
KatFysh Offline OP
KatFysh  Offline OP
Falconer, NY
Yes.. there are 2 problems with the Liberty.. When my friend 1st started telling me the problem, I thought resistor.. Then, later, he came back with the info about about not getting the heat out at all, at times..I thought blend door but wasn't positive. I know back between '91 and '97 at a Linc/Merc dealer, 7x out of 10, the problem was the blend door. Thanks guys. Sorry for any confusion..
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: KatFysh] #1500264
09/15/13 10:19 PM
09/15/13 10:19 PM
Western NY
19SuperBee70 Offline
Western NY
I have a 95 wrangler 4 cylinder 5 speed. I think all the 4 cylinders came with 4.10's. I had 31's on it for awhile, drives fine but barely will do 65 on the freeway with a headwind. Also a little tough on hills at speed. i would stick with a 6 cylinder or a smaller tire. Around town it will be fine.
Re: Question of 2 Jeeps..Liberty and Wrangler [Re: 19SuperBee70] #1500265
09/22/13 05:32 PM
09/22/13 05:32 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
4.10s for the 5 speed, and 3.73 for the automatic.
You can make do with 33s and the 4.10s, but that automatic will make you miserable with any tire larger than stock.
