How tight can I run valve lash? #1500215
09/11/13 07:40 PM
09/11/13 07:40 PM
GEORGIA
barracuda7199 Offline OP
GEORGIA
440 .557 mopar cam calls for .028 intake .032 exhaust. This seems excessive and a waste of lift. How tight can I go before damage occurs? Am I stuck with this lash and need to either let it be or buy a newer design camshaft? I would like to try the small lunati voodoo solid to b honest. Thanks for your time
Re: How tight can I run valve lash? [Re: barracuda7199] #1500216
09/11/13 08:09 PM
09/11/13 08:09 PM
central, fl
turboduster Offline
turboduster  Offline
central, fl
You being honest means that you want some assurance/permission to buy a new cam. Go for it.
Re: How tight can I run valve lash? [Re: barracuda7199] #1500217
09/11/13 08:12 PM
09/11/13 08:12 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
The ramps on the older cams require more lash than the newer. Set it like it says and you wont have any lash problems.
Re: How tight can I run valve lash? [Re: barracuda7199] #1500218
09/11/13 09:17 PM
09/11/13 09:17 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
12 or 14 thou cold will be fine you might want to check piston to valve
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: How tight can I run valve lash? [Re: barracuda7199] #1500219
09/11/13 11:15 PM
09/11/13 11:15 PM
Normally .010 tighter (maybe a tiny bit more) is okay on the loose lash cams like the Mopar and Isky with .028 lash. If it seems to be better with tighter then you need a bigger cam
Re: How tight can I run valve lash? [Re: Cab_Burge] #1500220
09/11/13 11:34 PM
09/11/13 11:34 PM
GEORGIA
GEORGIA
Sounds like I need to break the feeler gauges out. Lunati recommended this cam http://item.mobileweb.ebay.com/viewitem?itemId=171007248992&cmd=VIDESC
What would you recommend?
Re: How tight can I run valve lash? [Re: Cab_Burge] #1500221
09/12/13 07:59 AM
09/12/13 07:59 AM
gregsdart Online content
gregsdart  Online Content
I pushed the 590 grind even further, setting the lash down to .014 cold with iron heads. My big stroker liked it. The ramps will be more gentle when you tighten the lash, so the duration goes up, but the first part of the actual lift is a bit lazy. The danger point is not letting the valve seat properly, which with .014 hot shouldn't be an issue at all.
Re: How tight can I run valve lash? [Re: barracuda7199] #1500222
09/12/13 08:10 AM
09/12/13 08:10 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I ran my old MP 528 solid at .022/.026 It seemed to run better, have more "pull"
Coming soon!!!!
Re: How tight can I run valve lash? [Re: barracuda7199] #1500223
09/12/13 01:28 PM
09/12/13 01:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My Isky solid roller calls for .026 and I set em at .014 cold w/alum. heads which brings it to around .20 hot and never an issue after 8+ years.
Re: How tight can I run valve lash? [Re: Thumperdart] #1500224
09/12/13 06:37 PM
09/12/13 06:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran the .557 cam at .024. Ron
Re: How tight can I run valve lash? [Re: 383man] #1500225
09/12/13 06:48 PM
09/12/13 06:48 PM
Az
Crizila Offline
Crizila  Offline
Az
Run my Comp solid blower cam at .012" cold across the board - per spec.
Fastest 300
Re: How tight can I run valve lash? [Re: 383man] #1500226
09/12/13 09:51 PM
09/12/13 09:51 PM
GEORGIA
GEORGIA
is that hot intake and exhaust?
Re: How tight can I run valve lash? [Re: barracuda7199] #1500227
09/12/13 10:12 PM
09/12/13 10:12 PM
ill
dennismopar73 Offline
ill
I have seen zero lash,!!! run fast!
Re: How tight can I run valve lash? [Re: dennismopar73] #1500228
09/12/13 11:12 PM
09/12/13 11:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
On a hydro yes but a solid?
Re: How tight can I run valve lash? [Re: barracuda7199] #1500229
09/12/13 11:40 PM
09/12/13 11:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No that was cold on both intake and exh. Ron
Re: How tight can I run valve lash? [Re: Crizila] #1500230
09/12/13 11:51 PM
09/12/13 11:51 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
FWIW - I'm running my Comp hydraulic roller (Magnum SB) with solid roller lifters at .008" cold.
Re: How tight can I run valve lash? [Re: Thumperdart] #1500231
09/13/13 12:28 AM
09/13/13 12:28 AM
ill
ill
Solid cam ! ran it for awhile ! It did run fast!
so long as a cam can get lubrication!
Re: How tight can I run valve lash? [Re: dennismopar73] #1500232
09/13/13 01:36 AM
09/13/13 01:36 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
Comp said 26 and 28 on my 686 lift solid roller I went 16 and 18 and zero problems
