A/C hose restoration #1500079
09/11/13 12:46 PM
09/11/13 12:46 PM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Anyone have a process or place that does a nice job restoring a/c hoses and fittings? Want them all to fit as they did origianlly with new hose to eliminate leaks. Did a search already but didn't see a solid way of restoring them.
Re: A/C hose restoration [Re: Siba] #1500080
09/11/13 01:34 PM
09/11/13 01:34 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I did this about 18 months ago....I sent them to a guy here in TX...he removed the OE hose ends, blasted, painted, then re-installed new lines and shipped them back to me...his work was incredible and about as close to OE as I think can be got...
ericklaskowski@aol.com
it wasn't cheap....but well worth it...he's in San Antonio, TX
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: A/C hose restoration [Re: shanker] #1500081
09/11/13 01:37 PM
09/11/13 01:37 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
How bout some pics to show them off?
Re: A/C hose restoration [Re: fastmark] #1500082
09/11/13 01:42 PM
09/11/13 01:42 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
he has an ebay store where he also sells stuff.
http://www.ebay.com/sch/Texaserick/m.html?_ipg=50&_sop=12&_rdc=1
I don't have any pictures of the hoses handy because I havn't installed them yet (got sidetracked on project ramcharger and the weather cooled down )
Re: A/C hose restoration [Re: shanker] #1500083
09/11/13 01:44 PM
09/11/13 01:44 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
my hoses were unique because I didn't want any late-model aluminum crimped ends...I wanted all OE...and for the most part, he got it done
Re: A/C hose restoration [Re: shanker] #1500084
09/11/13 01:57 PM
09/11/13 01:57 PM
NewEngland ( Ma, Ct )
MoparJoeMA Offline
MoparJoeMA  Offline
I restored a 70 RT/SE with air about 2 years ago.. Sent all the hoses to Classic Auto Air down in Fla.. The changed all the hoses to be R 134 compliant replated the ends ect.. The looked and worked fantastic.
Wasn't cheap as I remember tho either 700 or 900 bucks.
Might want to give them a call and inquire..1-877-342-5526
Re: A/C hose restoration [Re: MoparJoeMA] #1500085
09/11/13 11:10 PM
09/11/13 11:10 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: A/C hose restoration [Re: Siba] #1500086
09/11/13 11:31 PM
09/11/13 11:31 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Simple,pressure test them, have them glass bead blasted, and find a place to re plate the ends. The plating does not stick to the rubber.
Re: A/C hose restoration [Re: 71birdJ68] #1500087
09/12/13 12:08 PM
09/12/13 12:08 PM
Troy,MI
Siba Offline OP
Siba  Offline OP
Troy,MI
Thanks for all the replies. The hardest part to this job has been finding all the hoses. I think I'll go the route of testing and re-plating for now. I have plenty of R12 if something doesn't work out.
