degree of difficulty in changing 67gtx door handle #1500040
09/11/13 10:15 AM
09/11/13 10:15 AM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
how difficult in changing a outdoor 67gtx door handle... unfort it seems the only ones u can find are the repops, and the qty def not on par with oem..
the button when pushed in..stays in... need to pry it out with a screwdriver... it seems all u need to do for the install is take off the inside
handles, panel, have the window raised, and its 2 bolts... seems simple enough... but it can't be... or can it... for a novice??
thanks
Re: degree of difficulty in changing 67gtx door handle [Re: paris401] #1500041
09/11/13 10:30 AM
09/11/13 10:30 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
thanks
That pretty much sums it up, I think it's 3 bolts though ?? 2 on the button side and one at the other end of the handle, don't forget a new gasket and you have to remove and reinstall the pull rod.
if the handle itselfs chrome is still good you might be able to fix the button issue. Is your replacement Chrysler boxed or an offshore import piece of crap ?
Re: degree of difficulty in changing 67gtx door handle [Re: JohnRR] #1500042
09/11/13 11:16 AM
09/11/13 11:16 AM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
the handles are 3-4yrs old, and the car has been rarely used...maybe 1/2 times over that period..
the handles look fine, BUT, when I replaced the orig's 3-4 yrs ago, u could tell the repops were cheap/cheap Chinese crap... but that's all I could find..
I bought another set yesterday off ebay (trim parts was the name on the boxes), and says made in USA... comes with the gaskets and
screws (2)...
and u think I can undertake this 'project' ???... if I run into any hiccup, i'm driving up to mass for your help...
thanks
Re: degree of difficulty in changing 67gtx door handle [Re: paris401] #1500043
09/11/13 12:03 PM
09/11/13 12:03 PM
I haven't had a handle .. off the door ... in my hand so I couldn't remember how many screws hold it o, I think you should be able to handle it , the hardest part will be getting the door panel off without damaging it , buy a panel pulling tool .
Otherwise you'll have to drive up to N.H. , I moved out of the liberal cesspool 7 yrs ago ...
Re: degree of difficulty in changing 67gtx door handle [Re: paris401] #1500044
09/11/13 04:15 PM
09/11/13 04:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Trim parts normally makes top notch stuff
Re: degree of difficulty in changing 67gtx door handle [Re: TJP] #1500045
09/18/13 08:45 AM
09/18/13 08:45 AM
new york
P
paris401 Offline OP
paris401  Offline OP
P
new york
johnrr...after hours of pulling and pushing, I finally changed the door handle... actually the most time was spent looking for the clip that holds the rod onto the door handle... it was small, black, and I dropped it in the grass...
but its done... and so far working like a charm... on to the next project
Re: degree of difficulty in changing 67gtx door handle [Re: paris401] #1500046
09/18/13 09:46 AM
09/18/13 09:46 AM
Re: degree of difficulty in changing 67gtx door handle [Re: JohnRR] #1500047
09/19/13 03:55 PM
09/19/13 03:55 PM
georgia
mopa Offline
mopa  Offline
georgia
My Demon had the same problem and when I pulled the panel it turned out to be a broken plastic clip that holds the rods together. That is an easy fix if it is the problem.
Re: degree of difficulty in changing 67gtx door handle [Re: paris401] #1500048
09/19/13 04:36 PM
09/19/13 04:36 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
remove inside armrest,inside door handle,window crank and door panel. Two nuts and a clip hold it in. Not hard except pulling the door panel...I use a small wide pribar to get close to the clips and pop them out. Window must be in the up position
