Edelbrock 340 horsepower? #1499957
09/11/13 02:19 AM
09/11/13 02:19 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I rebuilt my 340 about 3 months ago and got my car dynoed last week. First pull was best and it made 314 horsepower at 5500 rpm to the hubs & 343 ft/lbs torque
Dyno guy said the AFR's were good so it was not needed to touch the carb
My combo is a 340 bored .030 over
Edelbrock heads out of the box
Edelbrock RPM cam and RPM intake
Stock cast crank 3.31 stroke, rods, rocker arms
forged pistons 9.5 to 1 compression
hydraulic lifters
650 cfm holley double pumper
1-5/8" headers to 3" exhaust with x pipe
manual trans
I figured with 10% drive train losses that my engine is making 345 horsepower to the flywheel which is 1 hp per cubic inch. I am no engine expert or anything and am happy with the motor as its really fun on the street. Just wondering if this is typical power output with this combo?
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Edelbrock 340 horsepower? [Re: RylisPro] #1499958
09/11/13 02:25 AM
09/11/13 02:25 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You'd have to post that camshafts specs for people to give and opinion of your numbers.
Why 3" exhaust with that combo? Seems a bit much.
Re: Edelbrock 340 horsepower? [Re: autoxcuda] #1499959
09/11/13 02:34 AM
09/11/13 02:34 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
My cam specs are
http://www.edelbrock.com/automotive_new/mc/camshafts/locator.php?part_number=7177&submit=go
Camshaft: Performer RPM
Part #: #7177
Vehicle Type: CHRYSLER
Engine Application: 318-340-360 V8
RPM Range: 1500-6500
DURATION AS ADVERTISED INTAKE: 308° EXHAUST: 318°
DURATION @ .050 INTAKE: 234° EXHAUST: 244°
LIFT @ CAM (Lobe) INTAKE: 0.325" EXHAUST: 0.34"
LIFT @ VALVE INTAKE: 0.488" EXHAUST: 0.510"
I got a great deal on a stainless 3 inch exhaust and could not pass it up.
It sounds great and is actually not too loud with an X-pipe
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Edelbrock 340 horsepower? [Re: RylisPro] #1499960
09/11/13 02:47 AM
09/11/13 02:47 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Your compression ratio is a bit low. Why did you drop it to 9.5:1? With the aluminum Edlebrock heads, 10.5:1 should have been easy.
For the CR you have, your power output is about as one would expect. Pretty conservative build from what I can tell. With just a bit more work, you could have been up closer to 400 HP and still very streetable.
Astrobuf
So, are you really a Rocket Scientist?
Re: Edelbrock 340 horsepower? [Re: astrobuf] #1499961
09/11/13 03:15 AM
09/11/13 03:15 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Closer to
20% loss for a stick
22% for an auto
I am truckless..
Re: Edelbrock 340 horsepower? [Re: astrobuf] #1499962
09/11/13 03:29 AM
09/11/13 03:29 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Aha! That might explain it. The engine has the same pistons from decades ago and I'm just working with what I got. Pistons are TRW L2385's and compression might actually be 8.5 to 1 ? I think my heads are 63 cc's
Next 340 that I build will have higher compression and that Ritter aluminum block
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Edelbrock 340 horsepower? [Re: astrobuf] #1499963
09/11/13 04:14 AM
09/11/13 04:14 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Astrobuf
With the gas out here running 91 octane and true measured 9.5 to 10.1 with a smaller cam is realistic.
Sure it would make more HP with higher compression but he might end up dialing the timing back doing a lot of street driving in traffic in a city with true pump 91 octane.
314 wheel dyno HP at 20% drivetrain loss with a stick is 392.5 flywheel HP. Pretty close to the 400 HP number.
Re: Edelbrock 340 horsepower? [Re: autoxcuda] #1499964
09/11/13 11:20 AM
09/11/13 11:20 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I think on this Dynapack dyno that 10% is pretty accurate. I dynoed my S2000 on there and made 216hp +21 =237hp which is right at the factory rating. At 20% it would be at 270hp and no way a stock 4 banger would make that.
I am still happy with 345hp and a healthy engine
Next time I build, I know which areas to address
Cam, compression etc...
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Edelbrock 340 horsepower? [Re: RylisPro] #1499965
09/11/13 01:24 PM
09/11/13 01:24 PM
dogdays Offline
dogdays  Offline
Sounds like a nicely balanced package. No need to mess it up looking for a bigger number.
R.
Re: Edelbrock 340 horsepower? [Re: RylisPro] #1499966
09/11/13 03:49 PM
09/11/13 03:49 PM
MN
astrobuf Offline
astrobuf  Offline
MN
Most likely, the pistons are too far in the hole and you should have decked the block.
Astrobuf
Re: Edelbrock 340 horsepower? [Re: RylisPro] #1499967
09/11/13 04:02 PM
09/11/13 04:02 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sounds about right for a 340 with what you have, are the heads ported or OOTB? One more thing, I thought you were going to do a Predator headed BB awhile back?
Re: Edelbrock 340 horsepower? [Re: astrobuf] #1499968
09/11/13 04:04 PM
09/11/13 04:04 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I remember when I re-assembled everything that the pistons were level with the block
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Edelbrock 340 horsepower? [Re: WO23Coronet] #1499969
09/11/13 04:13 PM
09/11/13 04:13 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
The heads are untouched and are out of the box
I still have all my Predator stuff but I'm getting rid of it because I'm going road racing and its overkill
I want to do an all aluminum 340 with the Ritter aluminum block. If the aluminum small block came out years ago I would never have bought the Predator setup
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Edelbrock 340 horsepower? [Re: RylisPro] #1499970
09/11/13 04:36 PM
09/11/13 04:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
When I built my last 340 in 2007, I used KB-243 standard pistons and they were .029" above the deck.
Then I used the open chamber Edlebrock heads designed for the hi compression early motors. I CC the heads and had 10.4-1 compression and it runs fine on 91 octane fuel for close to 18K miles now.
IMO, I hate decking heads and blocks, I rarely have it done as it messes up your top end fit. Plus you can never put it back.
Use the right parts and don't cut the heads or block, imo.
Re: Edelbrock 340 horsepower? [Re: Challenger 1] #1499971
09/11/13 09:27 PM
09/11/13 09:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You normally lose more like 20% in the drivetrain. I would say you have more like 375 to the flywheel. Ron
Re: Edelbrock 340 horsepower? [Re: Challenger 1] #1499972
09/12/13 01:17 PM
09/12/13 01:17 PM
MN
astrobuf Offline
astrobuf  Offline
MN
Exactly right!
Astrobuf
Re: Edelbrock 340 horsepower? [Re: astrobuf] #1499973
09/13/13 03:00 PM
09/13/13 03:00 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Sounds about right for what you have. The heads might have needed some touches to be perfectly as advertised anyway.
